Cutting stick on LED strips
john.r2
Mar 27, 2023
20
I've got some led strips which consist of tiny SMD led's glued to a sort of tape flexible pcb which is attached to a flexible plastic. The supplier says that it can be cut to any size. Looking at the PCB, i can see loads of small tiny SMD resistors too.
My question is, by cutting it at random place, does it not effect the current draw and voltage etc to power the LED's safely?
Martaine2005
May 12, 2015
5,315
Can you give a link to them?.
If each LED is in parallel, then yes you can. But if series strings, then no.
Martin
kellys_eye
Jun 25, 2010
6,512
It will affect the current draw - shorter sections, lower current etc - but the cut strips will all operate exactly the same regardless of their cut length.
