David L. Jones
- Jan 1, 1970
- 0
I second the motion.
Me too.
Even if DJ did beat me in the 2007 PIC Circuit Cellar contest! :->
Dave.
MS actually will give you quite good help... if you pony up for the
several-hundred-buck-per-incident support phone lines. :-( (And there's no
charge if the problem turns out to be due to a bug, supposedly.)
Gee Jan, I don't see anything wrong with DJ getting paid to
write software. And we all stand to benefit.
What's wrong with that?
Thanks RH, and thanks DJ.
Because they are the ones distributing the binaries. Though I agree it
does not make much difference here - but in general how do we know if
the official sources contain all the modifications needed to make the
software build correctly? It is safest if the code is available, at
least in principle, from a single source (i.e. the same one that
supplied the binaries).
Looks like they did not test on a lot of hardware platforms.
There are several 45G models.I'm surprised that so many manufacturers seem to do this. I've always
figured it's been marketing-driven -- the marketing guys see that the WRT54G
is selling like gangbusters, so they figure it's "risky" to release, e.g., the
WRT55G. Still, there could at least release a WRT54Gv2, which to most
consumers still says, "better than the first!" and doesn't risk the loss of
model recognition.
Chip vendors do the same thing. If volume gets high enough
they often switch to a new version of the silicon that is
less expensive to manufactur but still meets the same specs.
I gather that vendors have procedures so major customers get
notified and/or get a chance to test the new version without
getting surprised in case there is some obscure not-documented
feature that they are depending upon which is different in the
new version.
I was aware of most of those variations. my WRT54G appears to be
version 5 with Firmware Version: v1.00.1
My point was that they are turning it into a family of products, to
capitalize on the popularity of the original. I know different versions
of the original have been released.
