Darlington Phototransistor - can i fudge one from an NPN phototransistor ??
Nick Mulder
Oct 13, 2005
43
I am keen to make the circuit outlined here:
http://www.aaroncake.net/circuits/slave.htm
it calls for a '2N5777 NPN Darlington Phototransistor' of which I am yet to find a supply of here in NZ - upon looking at the symbol used for the Darlington Phototransistor in the cct diagram in the link above it seems to be two transistors cascaded together one being a Phototransistor and the other a normal transistor...
I dont know much about transistors and especially darlington types but if they are simply a bundled package of two transistors could i make a substitute from the discrete versions ?
I ask this as I have a simple NPN Phototransistor here already and a PNP and NPN from other projects I could use..
is it as simple as that ? :p
ante1
Jan 24, 2004
4,138
Hi Mulder,
You could try Farnell http://nz.farnell.com/jsp/home/homepage.jsp  nr. 1021141, it should work.
audioguru2
Apr 6, 2004
12,026
In "the good old days", there was a photoSCR that could do a remote strobe-flash, all by itself. I think it was made by GE.
ante1
Jan 24, 2004
4,138
Hi Mulder,
I don’t know where I got that number, it should be: 327542, sorry! :-[
It's cheaper too! ;D
