Data Decoding at 10 Gbit/s
  • Thread starter Martin Schimmelpfennig
  • Start date
I would like to design a 16 channel SERDES ASIC in 0.13µm running at 10
Gbit/s per channel. For transmission a standard 8B/10B is to be applied. My
concern is now how to achieve real-time decoding of the 8B/10B transmission
code at 10 Gbit/s with that technology? Can that easily be achieved? What is
state-of-the-art? As far as I know the 8B/10B decoding cannot be down by a
simple lookup table because the corresponding code words depend on the
running disparity of the previous transmitted data and there is no simple
1-on-1 mapping.
Since the 8B/10B coding is a self-synchronizing (?) code (i.e. the clock can
be retrieved from the transmitted data) I would have to use a kind of clock
recovery at my SERDES input. Another question would be if a PLL at the input
is advisable or even feasible at data rates of 10 Gbit/s.
I would be very thankful if some of you could give me a hint.
Best Regards
Martin
PeteS
Gbit/s per channel.
You are not the only one. I know Mellanox (http://www.mellanox.com/) is
working on it to support the InfiniBand (http://www.ibta.org) QDR rate
(10Gb/s per pair). Others are working on it for higher speed versions
of PCI express, at the least.
As it is for virtually all other flavours of data transmission at these
rates nowadays (Ethernet, Fibre channel, InfiniBand, PCI Express)
My
Others are certainly achieving it at 5Gb/s
What is
1-on-1 mapping.
You don't seem to have a firm grasp of 8B/10B encoding. I would
strongly suggest you look that up first. Note that the running
disparity enables a serdes to detect which 'sense' the input signal has
been connected and automatically switch the 'p' and 'n' inputs
appropriately.
Inherently so, and designed specifically with that in mind. Maximum run
length = 5. Strictly speaking, that makes the system 'source
synchronous'
I would have to use a kind of clock recovery at my SERDES input.
Of course. This is a well understood technology (although not
necessarily at 10Gb/s)
There are PLLs operating well beyond this in a number of areas
Get the background on 8B/10B encoding (part of the IEEE802.x specs),
clock recovery techniques (google is your friend) and the latest high
speed existing serdes devices. Without that background, I fear you will
have a frustrating time.
Best Regards
Martin
Cheers
PeteS
W
Weng Tianxiang
Xilinx have filed for 22 patents to implement 8B/10B algorithm.
IBM filed the 8B/10B original patent in 1981. Now 8B/10B algorithms are
so popular that all SERDES specifications use the 8B/10B like what
ASCII is to computer industry.
Most of 22 Xilinx 8B/10B patents are pending. You may print out what
have been approved as a patent. Their experiences will certainly help
you do understand how to design a 8B/10B circuit.
Sorry, all those circuits are still pending. One that is approved is a
software flow map.
Weng
K
Kai Harrekilde-Petersen
Martin Schimmelpfennig said:
Gbit/s per channel.
Vitesse is certainly achieving >10Gbit/s in 0.13um - ISTR that they
also have done 12.5Gbit/s. They have chips doing 10Gbit/s SERDES for
at least 2 years now, but as far as I remember, this is only 1-4
channels per chip. YMMV.
It's only a 1GHz encoding/decoding rate (parallel datarate), so I
don't see why it should be a problem. Again, Some/all of Vitesse
10Gbit/s chips implement 8B/10B.
Disclaimer: I don't work Vitesse (any more).
Kai
JosephKK
Martin said:
My concern is now how to achieve real-time decoding of the 8B/10B
transmission code at 10 Gbit/s with that technology? Can that easily be
achieved? What is state-of-the-art? As far as I know the 8B/10B decoding
cannot be down by a simple lookup table because the corresponding code
words depend on the running disparity of the previous transmitted data and
there is no simple 1-on-1 mapping.
can be retrieved from the transmitted data) I would have to use a kind of
clock recovery at my SERDES input. Another question would be if a PLL at
the input is advisable or even feasible at data rates of 10 Gbit/s.
Best Regards
Martin
Congratulations PeteS and Kai, you told this willfully ignorant SOB graduate
student trying to get you to do his schoolwork for him to do the work
himself. Better still you gave him good paces to learn what what he should
have found out for him self if he could been bothered to google a bit.
