data transmmition with laser pointer
eplanet
Mar 5, 2007
88
hi friends
have you any idea for sending data (0 or 1) with laser diode to receiver diode with PIC micro controller and indicate to LCD 2*16 characterize lcd??
thanks
eplanet
Mar 5, 2007
88
i have laser pointer (use in presentation) and i want to transmit data up to 1meter (zero and one logical method ) , with receiver sensor. for first in this issue i need circuit for amplify signal (fast switching) in receiver. look at this schematic !!
i know how can i make signal in transmitter with micro controller but i have problem with using 2pin receiver sensor.
if you have any idea for amplify signal in receiver circuit?
Hero999
Oct 28, 2007
2,433
Have you Googled?
As it only neds to transmit over 1m why not drop the laser idea and use a standard IR LED and remote control receiver IC?
ARUN CHOWDARY
Jun 12, 2010
55
yes perfectly you can transfer data from laser pointer up to 10 meters also by using the laser of low beam width by using the high response devices in the receiver circuit you can achieve high speed and by using high gain amplifier you can raise the level of the output to the peak level
in the transmitting stage the program for converting the asii to binary is needed you should use the keyboard interface by the RS 232 socket by giving input in ASII code it will convert into binary digits then the output is connected to the laser
