DC / AC Inverter Design Assistance
Iskandar
Sep 2, 2016
5
Hey guys, I am kinda new in power electronics and I have a task at hand that requires assistance.
I have an assignment to build a SMPS. My prof gave me a breakdown that once I rectify the Input from AC (230V rms), 50Hz to a DC (300V), I need to channel the output through a DC / AC Inverter. I have been searching the net for a pretty beginner level decent explanation on the principle of operation but I got confused along the way. I have come across the fundamentals of the SMPS Flyback Converter. Is that a better option to use instead?
Here is the block diagram from my prof
Rectify from Mains -> DC/AC Inverter -> Transformer -> Rectify -> 2 outputs , (12V, 5A),
Thanks in advance
Consider whether you need isolation.
Which topologies will give you that?
Iskandar
Sep 2, 2016
5
Hi Steve, my application would be ideally, to power up the television that requires about 100 to 120 watts. So Im guessing it should be isolated switch mode power supply.
I have seen quite a variant of SMPS, Im' guessing the Flyback Converter as it introduces a transformer and it allows multiple output in the secondary side by just introducing extra windings.
Im confused why did my prof clearly defined a DC/AC inverter. Hope my doubts can be clarified. Thank you
Look at a basic description of why smps power supplies are used, and how they operate.
The transformer you mentioned is a big clue.
Iskandar
Sep 2, 2016
5
The reason smps are much favoured instead of linear regulators is because to improve efficiency and to improve cost and design. Am I safe to say I have been fooled into thinking that I needed to build a DC/AC inverter when I can just build a simpler circuit based on the Flyback Converter that can essentially solve the problem? I apologise for my lack of knowledge, kinda new into this power electronics stuffs.
You've noted that the fly back design requires a transformer. Can these operate from DC?
What are the differences between transformers used in linear power supplies vs those in switch mode power supplies?
Iskandar
Sep 2, 2016
5
My apologies, a transformer cannot be used to step up/ step down a DC voltage. It can only be done with an AC voltage. The transformer that was mentioned in a flyback converter actually uses a inductor that was split to act a transformer, saving space.
Moving forward, can I clarify,
1. The rectified DC output (300V DC) I have to inevitably convert to AC using the inverter. But is it possible to receive a 300V DC and convert to an AC, thus I can't seem to grasp the concept of DC/AC inverter, find any cause I only managed to find low voltages (12V for example) to (240V for example)
2. I do not need a Flyback Converter at all then ?
Sorry for the long post. I hope you are patient with me. Thank you.
Perhaps if you google "how does a switch mode power supply work"...?
