DC Motor Driver Problem
endoramax
Jul 9, 2021
8
Hi Everyone,
I am using this DC motor driver for my tennis ball launcher. When I was testing the machine on the outside one dc motor stopped after a while. I checked two motors that they worked as well. I tested the DC motor driver then I realized that there are no voltages in output. Also, I checked the DC motor driver there is no burn or damaged component on it.
I need to find a problem but I don't have enough experience in electronics troubleshooting. How can I check this card step by step?
Best Regards.
Minder
Apr 24, 2015
3,561
That appears to be one of those $2 - $3 version off ebay, usually a 555 PWM, You would need to do a little reverse-engineering of the circuit, i.e. draw it out on paper and go from there.
WHONOES
May 20, 2017
1,242
I notice that it has a fuse on board. Is it intact?
endoramax
Jul 9, 2021
8
Yes it is so cheap and I replaced them with a new one but I want to know why driver stoppped immediately. For example, problem is related to high power consumption (ampere) I need to change some components also I need to decrease the friction level so on.
Only you will be able to check the current draw but I'm guessing it's more than the so-called rated current of 10 amp.
Probably popped the output element whatever that is.
More than likely a mosfet and again, more than likely the one on the large heatsink.
It's a wonder the fuse is intact, that sort of blows my idea out of the water.
Martaine2005
May 12, 2015
5,318
I remember reading an ebay listing about a similar speed controller.
Something like "2A continuous with supplied heatsink and 10A with a larger separate heatsink". Not those exact words.
Also, to switch on with the lowest setting and slowly ramp it up.
What motor are you using? A 775 - 795 type? Even these small types can have a stall current higher than your rated controller.
And remember, each time a ball goes through your machine, it loads the motor heavily.
Martin
Minder
Apr 24, 2015
3,561
What rating/value is the fuse?
You could try a fast-blow type if it does not cause nuisance blowing.
Or just drop the value.
bertus
3,877
Sounds like the heatsinks are way too small.
Or it could be that the mosfets are not switched fast enough.
The time a mosfet stays in the linear region causes the mosfet to heat-up.
Also when mosfets are not driven all open (gate voltage to low) , heat will be the result.
@endoramax , Does the board have a voltage regulator for the 555?
If so, what voltage does it supply?
Next to the 555 pwm circuits, you will find circuits using the LM339.
Here is an example:
https://www.masinaelectrica.com/dc-motor-speed-controller-pwm-0-100-400hz-3khz-freq/
Bertus
endoramax
Jul 9, 2021
8
Here is an example:
Bertus
Hi
I am not sure the board has a voltage regulator vice versa. I supplied 24V but this time I supplied 27.4V (with lipo) for a short time. Could it be affected?
Thank you
Martaine2005
May 12, 2015
5,318
Did it work before with 24V? and now after 27.4V, it failed?
The item description says 12V - 40V input, so it 'shouldn't' be a problem. But I bought some 12V - 24V motors which exploded at 18V.
Martin
