DC Motors and speed control
Status
Not open for further replies.
Jon Cavendish
May 2, 2016
Hello EP!
New to the forum, not so much to electronics (though I am no expert).
A quick run down:
I'm building a rotary speaker cabinet (Leslie-style). This is a standard speaker with a baffle that rotates in front of it to throw the sound around the room, giving excellent Doppler/chorusing effects.
The originals were built with 2 speeds (fast/slow) using an AC motor stack that had a large motor for fast and a small one for slow. This setup works just fine, but it is mechanically noisy and has too many moving parts for my liking (after all, it's 70 year old tech).
I want to build a DC motor circuit that can turn the baffle at 2 speeds, and have those speeds be switched by a foot pedal. I have built a switching rig using relays and 12vDC to switch AC mains. I am good with an iron and can read a schematic.
My question is this:
What is the best motor to use, and what is the simplest way to build the speed controller? I have read a bit on using PWM to slow the dc motor, and also that you can use a varied voltage to change the speed. I'm really just at the starting point, so any info you can offer will be much appreciated!
Feel free to send links to other threads/forums if this has already been answered somewhere before.
Thanks!
-Jon
Alec_t
Jul 7, 2015
3,821
To keep noise down I'd go for a brushless motor rather than a brushed one, and use belt drive rather than gear drive.
Arouse1973
Adam
Dec 18, 2013
5,178
I was thinking a large RC Servo, modified for continuous rotation if needed or of it's just back and forth then just PWM it.
Adam
duke37
Jan 9, 2011
5,364
A resistor in series with a DC motor will reduce its speed, chose resistors to get the two speeds you want.
You could look at a modified windscreen wiper motor which would give masses of torque at about the correct speed. A trip to the scrap yard is called for.
I spent a lot of time repairing a Hammond organ, I later learned that it had been scrapped and the Leslie speaker used by a band. Sacrilage!:(
Minder
Apr 24, 2015
3,561
If mechanically noisy using a BLDC motor is not going to change a thing, I have used ex T.M. at 5Khz-10Khz PWM with no electrical noise evident.
M.
Minder
Apr 24, 2015
3,561
Incidentally Brushless motors come in two flavours, BLDC and 3ph AC, both identical in construction, but the commutation and power applied is completely different.
Delta Prime
Jul 29, 2020
2,995
. I am always interested in sharing my knowledge and experience with other people who are passionate about motors
Me too. I don't regurgitate textbooks. You ever had an accident working on a brushless DC motor? Funny tail , close call, something unusual happened, tell me a little about that?
14,485
guys, this was a VERY OLD thread, Please always look at the last posted day before resurrecting the dead
thread closed
Status
