## DC Sweep Result of Schmitt Trigger Inverter? ##
june
If I do a DC SWEEP of -0.5v~0.5v to a Schmitt Trigger Inverter,
Why do I see
Y:VOUT
----------------------------------- x: VIN
a b
(a=-0.2v, b=-0.19v)
If I dida TRANSIENT Simulation of an Inverter of question.
Y:VIN
----------------------------- x:time
Y:VOUT
------------------------------- x:time
What I want say is that the Inverter above has Hysteresis
Characteristic of a Schmitt Trigger Inverter.
However, if I do a DC simulation of the same Inverter of question,
(i.e. when the inverter is dc swept)
Y:VOUT
It seems to be just a normal Inverter.
Why does this Inverter shows an Schmitt Trigger Characteristics in
TRANSIENT sim, and a normal Inverter Characteristic in DC simulation?
Is this Inverter a Schmitt Trigger Inverter or a Normal Inverter?
Regards,
June
Jamie
Why do I see
Y:VOUT
a b
(a=-0.2v, b=-0.19v)
Y:VIN
Y:VOUT
Y:VOUT
Regards,
June
Hard to follow your description but I would say that in a DC model, you
are supplying a low and high input signal with no middle range. This
would make it look like a generic inverter, because you have quickly
gone past the hysteresis region and thus, no effect will be visible.
with a TRANSIENT simulation, you are supplying a ramp up and ramp down
and this will give enough time to see the hysteresis effect.
DC modeling most likely is to assume an ideal signal of 0 or fully on
with no ramp visible (slew/Skew times = 0.0) etc...
Of course, there is no such thing as an ideal condition. Simulators
must be forgiven for their bad insight!
http://webpages.charter.net/jamie_5"
