DC transformer power supply question, 9V dc too much ?
ElecTedII
Sep 20, 2012
7
Hi ALL!
I have this Omron Blood Pressure machine that I use on a daley basis. I've had it for awhile, the cheap plastic leed has twisted itself off, right at the base of the plug in AC to DC low voltage Xfer.
I just repaired it, maybe for the last time, because I'm down to hairs to solder on to.
The question is, as with many of you, I have plenty of AC-to-low-voltage-DC power supplies, hanging around doing nothing!
The Omron power supply puts of 6V DC, 500 ma.
The power supply I have with a good leed puts out 9VDC, at 500 ma. The qustions is, will that kill the BP machine? Or will it ONLY use what it needs, and the extra 3VDC won't matter ?
Many thanks, ElecTed II
I wouldn't advise it.
If I couldn't find a 6V 500mA power supply, I'd go for any power supply rated for 6V and more than 500mA first, then maybe I'd try a 5V power supply rated at 500mA or more.
Do you know if the current power supply is a switchmode supply? If it is, it normally light, and has a wide input voltage range (like 90 to 220V). If it's heavy and specifies a single input voltage (say 120V) then it has a transformer in it (and it is -- at best -- a linear power supply).
The above is important. If it has a transformer, it may not be well regulated. If it's a switchmode supply it likely is.
It is almost always going to be OK to replace a power supply containing a mains transformer with a switchmode one, but going the other way may cause problems in some cases.
edit: It's the extra current it won't use unless it needs it, not the voltage
ElecTedII
Sep 20, 2012
7
Got a pic of Xfer
Hi **Steve**,
Thanks for the reply.
Don't quite know whata switchmode Xper is. So I decided to take a pic of the Omron Xfer. You know....a picture worth .....
Many Thanks, ElecTedII
Note the input voltage. It's a single voltage, not a range. This power supply has a transformer in it.
If you have a multimeter, can you measure the output voltage? (I want to see how close it is to 6V. That will tell me more.
duke37
Jan 9, 2011
5,364
12W in, 3W out. Almost certainly a lossy linear supply.
OK, that means it is at least minimally regulated.
You probably need something between 5.5 and 6.5 volts at 500mA or more.
Before you plug it in, make sure the voltage is not more than 7V.
This should ensure you won't break anything.
Oh, and make sure the polarity is correct.
CocaCola
Apr 7, 2012
3,635
FYI you can get these wall warts on Ebay for a few bucks, or you can go to Radio Shack and get robbed at about $30...
