DC voltage reduction circuit needed
HANKMARS
Jul 28, 2019
517
The latest charge controller I purchased for my PV system has a max input voltage of 25 VDC. My panels produce 36 VDC. I'm looking for a DC voltage reduction circuit to insure that controller never feels any voltage above 20 VDC. Does anyone have a bare-bones, bullet proof buck circuit handy?
Alec_t
Jul 7, 2015
3,817
There are loads of DC-DC converters advertised online. Won't one of those do, if bought from a reputable source? No guarantee it'd be bullet-proof though.
HANKMARS
Jul 28, 2019
517
I did indeed order a 40A buck converter about an hour after posting this thread. However, this particular converter has a max input voltage of 35 VDC. My panels will reach 36.7 V, no load, therefore I will be using a shunt regulator that should guarantee that Vin,max is never exceeded. Quite a simple design by a friend. Shunt uses a power transistor, a zener diode and one carbon resistor. Zener will determine when shunt turns on.
HANKMARS
Jul 28, 2019
517
The DC-DC buck converter is the best-suited DC voltage reduction circuit that maintains constant voltage at 20 VDC for my panels with 36 VDC. The buck converter efficiently reduces the Vin while providing stable Vout. Buy a buck converter to step down the 36V input voltage of your panels to a constant 20V.
Hope this will help.
What I did find that I have on hand is a CV CC convertor which I will hopefully be testing with panels and charge controller, sometime this week. CV CC unit rated 40 A.
ramussons
Jun 10, 2014
475
Just make sure that the Shunt Transistor has an forced aircooled heat sink.
