Debouncing....at About 1Mhz
JosephKK
Tom Bruhns [email protected] posted to sci.electronics.design:
Just do it in a modern CPLD, and 10nsec should be easy. Though
there's a bit of overhead getting started in CPLDs, it's cool that
when you make a mistake in your logic or see some improvement, it's
just a re-route.
For logic (if you are willing to get away from your SN7474 and
SN7486
parts...), you could use LVC parts at 5 volts. They're fast.
Cheers,
Tom
And waste 99% of the CPLD? We are talking about a task that an old
22V10 is 10X overkill.
JosephKK
D from BC [email protected] posted to sci.electronics.design:
[snip]
just a re-route.
SN7486
Cheers,
Tom
Thanks for the headsup for the future.
Did a quick read on
http://en.wikipedia.org/wiki/CPLD
:O .ohhhh that looks scary...
Is CPLD work more complicated than programming microcontrollers with
assembly?
D from BC
No, not really, just different.
Tom Bruhns
Because the OP suggested there is a lot of other stuff in the whole
circuit. Or, if you don't like that answer, "because I like working
with small parts under a microscope." ;-) Though even better,
because I can re-program it with JTAG in-circuit, using the same
programming pod I use for many other parts.
Cheers,
Tom
N
Nobody
You can't tell whether an apostrophe would be required without the
remainder of the sentence. What he wrote was:
Oh come on... I think JFs (apostrophe used correctly?) has a logical
progression with low propagation in mind.
So, the question is whether your surname is "Fields" (plural) or "Field's"
(possessive); I shall assume the former, as I don't see any apostrophe in
your "From" header.
His use of your surname in that sentence wasn't posssesive. And if
it was, the abbreviation should have been "JFs'" with a trailing
apostrophe (plural possessive).
John Larkin
On Sat, 03 Nov 2007 18:32:05 -0800, D from BC
[snip]
Ok.....I'm going to look at your circuit.
As on..
http://s2.supload.com/free/Deglitch.JPG/view/
D from BC
As has been pointed out a few times, it inverts. So take the output
from Qbar.
I'd still go for the lowpass-schmitt.
John
I'm checking out how the Deglitch cct behaves when the frequency is
varied..
(I forgot to mention in my first post that the frequency can vary but
not the bounce period.)
The hairball circuits can react to varying pulse widths and have a
large operational BW.
And have less EMI, right?
It will probably screw up, maybe even lock up, now and then. And you
can't prove, or even be confident, that it won't. Simulating a circuit
like this with a clean simulated edge bounce is naiive; in real life,
all weird timings are possible, and the circuit itself will have part
tolerances, temperature changes, and signal history (stored in the
various ghastly RC glitch circuits) in a literally infinite set of
combinations. It's crap.
Since you seem enamored of this complex mess, I have little more to
say.
John
John Larkin
This has got to be a classic signal clean up problem....
I need a circuit that triggers on edge A, then ignores about 0.1uS of
jitter then triggers on edge B and then ignores a following 0.1uS of
jitter.
jitter.
[where edge A is low-to-high and B is high-to-low]
So, use a nonretriggerable monostable with rising clock to
make a pulse at A, another with falling clock to make a pulse
at B, and Set/Reset a flop flop with those. Use the monostable A
output to gate (inhibit) the B trigger, and the B output to gate the
A trigger. As long as the monostable time
is set longer than the jitter window, you're golden.
So what happens when a really fast spike fires both one-shots? What
happens when an edge comes in just about the time one or both
one-shots is timing out?
Well, the trigger/output propogation delay has to be shorter than
the delay to first false transition...
"Well" is a word you'll need to use often when hacking kluges like
this.
It's just like this:
"Debugging is twice as hard as writing the code in the first place.
Therefore, if you write the code as cleverly as possible, you are, by
definition, not smart enough to debug it.
Brian W. Kernighan"
Except that demonstrating that nontrivial async logic is safe is a
thousand times harder than designing it.
John
John Larkin
I tend to agree with Larkin...
Relative to his cct., everything else is a timing hairball.
However, the Larkin cct changes behavior at lower frequencies..
How so? It has no longterm memory of previous events, so it should
work at arbitrarily low rates.
Are you feeding it slow edges?
John
D from BC
your "From" header.
Groan...:p
Is this SED or alt.binaries.writingforperfection??
Although, I don't mind the feedback to prevent writing errors in the
future..but my writing bugs are the least of my technical problems.
1st priority...comprehension.
2nd priority...dotting i's (oh fk...apostrophe used correctly?)
D from BC
D from BC
On Sat, 03 Nov 2007 19:45:01 -0700, John Larkin
[snip]
Hairball.
John
Nope, apostrophes are used to form possessive of nouns, so it should
be "JF's". :)
http://owl.english.purdue.edu/handouts/grammar/g_apost.html
has a logical progression with low propagation in mind.
Yup. The positive edge processing is 5 gate delays from input to
output and the negative edge is 3. There's probably some
optimization that can be done, but I was just looking to prove the
validity of the concept.
If I understand it correctly..
It's got edge extraction.
It's got 2 parallel paths per edge type.
And 2 timers to knock out the fuzz.
I'm guessing the required shopping list for this type of circuit is :
A means to detect the 1st positive edge.
A means to detect the 1st negative edge.
An ignore timer for the fuzz after the 1st positive edge.
An ignore timer for the fuzz after the 1st negative edge.
Yes, but the timer is to keep the fuzz from firing the _other_
circuit once the first edge fires its own circuit.
Don't mind Larkin, he generally pooh-poohs everything that doesn't
come out of his shop. NIH, it's called. ;)
I have Larkin's circuit in LTSpice.. It's actually tough to beat for
prop delay and parts count.
The Xor part is cool..
Maybe call it an edge rectifier..I've never seen that before.
(Does that part have a name?)
But..but..but I can still try it in my app which already has a built
in 100khz f limiter.
D from BC
D from BC
John
When using fast edges but lower frequency...I think I spotted an
inversion effect..
In other words...the cct only goes in phase after a certain frequency
and 180 out of phase below a certain f.
I could be mistaken and might need a vacation...
When I get back I'll try to confirm.
Here's the test circuit I just started to work on. It's rough..
Output is Qnot.
RC values do provide correct operation for 100khz and up.
(Note: RC values used are only for evaluation..not actual build
values)
But.. I've lower f to 10Khz.
Note: ( My app never goes below 100khz anyway's...So this is just some
curiosity.)
Version 4
SHEET 1 880 680
WIRE 64 48 0 48
WIRE 352 48 64 48
WIRE 64 64 64 48
WIRE 352 96 288 96
WIRE 560 96 528 96
WIRE 64 128 64 112
WIRE -80 224 -80 48
WIRE 80 224 -80 224
WIRE 288 224 288 96
WIRE 288 224 144 224
WIRE 80 272 16 272
WIRE -80 288 -80 224
WIRE -80 288 -240 288
WIRE -48 288 -80 288
WIRE -304 304 -544 304
WIRE -544 416 -544 384
WIRE -544 544 -544 496
FLAG 432 144 0
FLAG 432 0 0
FLAG 64 128 0
FLAG -544 544 0
FLAG 560 176 0
SYMBOL Digital\\xor 128 176 R0
SYMATTR InstName A1
SYMATTR SpiceLine Vhigh=5V Vlow=0V
SYMBOL Digital\\buf -48 224 R0
WINDOW 39 -125 114 Left 0
SYMATTR SpiceLine Vhigh=5V Vlow=0v Td=0.2uS
SYMATTR InstName A2
SYMBOL Digital\\dflop 432 0 R0
SYMATTR InstName A3
SYMBOL res 16 32 R90
WINDOW 0 0 56 VBottom 0
WINDOW 3 32 56 VTop 0
SYMATTR InstName R2
SYMATTR Value 10k
SYMBOL cap 48 64 R0
SYMATTR InstName C1
SYMATTR Value 10pF
SYMBOL voltage -544 400 R0
WINDOW 123 0 0 Left 0
WINDOW 39 0 0 Left 0
SYMATTR InstName V3
SYMATTR Value SINE(2.5V 0.1 50000000 0 0 0)
SYMBOL voltage -544 288 R0
SYMATTR InstName V4
SYMATTR Value SINE(0 2.5 10000 0 0 0)
SYMBOL Digital\\buf -304 240 R0
SYMATTR InstName A4
SYMATTR SpiceLine Vhigh=5V Vlow=0v Trise=1nS Tfall=1nS
SYMBOL res 544 80 R0
SYMATTR InstName R4
SYMATTR Value 10k
TEXT -144 520 Left 0 !.tran 0 300uS 0 1nS
D from BC
D from BC
jitter.
jitter.
For retriggerable monostables, the extra edges will stretch the
output pulse; if the stable time is guaranteed longer than the
monostable period, that's OK too.
The nonclassic solution is filtering followed by a Schmitt trigger.
That introduces phase delay, of course, and senses some average
over time rather than the initial edges.
It seems to be the trend.
I realized some of those monostable requirements when I tried to solve
the circuit.
Also, I suspect John Fields ascii circuit and posted LTspice file use
similar approaches.
One channel for the positive edge processing. A timing action.
One channel for the negative edge processing. A timing action.
Some cross resetting and final decoding..
The sequence is something like this.
Trigger on positive edge.
Let fuzz pass by.
Clear negative edge in preparation for 1st incoming negative edge.
Trigger on negative edge.
Let fuzz pass by.
Clear positive edge in preparation for incoming positive edge.
The pita part is attempting low prop delay for 1st pos edge and 1st
neg edge.
The SN74LV123A retrig MM has a tpd of 11nS@5V at the top of the
datasheet.
D from BC
It would be simpler to learn how to terminate your signals properly...
It's not that.
It's to clean up the output of a comparator in my app.
The comparator is getting a damped ring signal due to some unavoidable
inductor resonance.
I've maxed out the amount of hysteresis I can put on the comparator.
All this is in a main feedback loop and the debounce cct has to be low
delay to enable the highest system frequency.
The higher the frequency in my app... the better. (Well..EMI aside..)
I really believe I'm not doing a bandaid solution..it's essential.
D from BC
John Fields
Yes, but there's more to it than that. Here's what you missed:
Notice that what he was talking about was my design and then go
here:
where it's all very clearly spelled out.
your "From" header.
Sorry, that won't work. Whether my surname seems to be plural or
not, the reference was to one person, JF, and to my design, which
clearly makes it singular possessive, requiring the apostrophe.
John Larkin
inversion effect..
The delay in the rc must exceed the bounce time. The rc tau is pretty
much the only way this circuit knows what time means.
John
John Larkin
If a $1.50 Coolrunner does the job, what difference does it make that
you're wasting 95% of the on-chip resources? We do FPGA designs that
run 15% macrocell use, and the customers pay the invoices just the
same.
22V10's seem to cost more than Coolrunners these days, anyhow.
John
W
whit3rd
The problem, as stated, requires a circuit to operate in four
different phases:
Phase A: wait for a rising edge, go high when it does
Phase B: stay high, ignore edges for 'a while'
Phase C: wait for a falling edge, go low when it does
Phase D: stay low, ignore edges for 'a while'
So, something with two monostables or latches or whatever is required,
because the four states require two bits of state information. And
there are two time periods of some (presumably known) duration to
be part of the mix. It's required BY THE PROBLEM to have some
kind of one-shot to handle that timing, unless you can use higher-
speed
synchronous logic somehow. And the sensitivity to
glitches inside the phases A and D is also required, because you can't
determine (at speed) anything suspicious about transitions during
those
phases.
Asynchronous logic can be scary, but this situation really calls for
it.
John Larkin
different phases:
speed
I posted a simple, fast circuit that works, is hazard-free, and has
few of the things that you say are "required by the problem."
Remember, the signal has states of its own, so the circuit doesn't
have to include all the states you enumerate.
it.
That's no reason to design hairballs.
John
F
Fred Bartoli
When I was a kid I did program 6800/6809 in hexa (no assembler
available). Well one of my first tasks was writing a line editor and an
assembler, all that in hexa.
I certainly would not do that for CPLDs.
F
Fred Bartoli
jitter.
jitter.
So, use a nonretriggerable monostable with rising clock to make a
pulse at A, another with falling clock to make a pulse at B, and
Set/Reset a flop flop with those. Use the monostable A output to gate
(inhibit) the B trigger, and the B output to gate the A trigger. As
long as the monostable time is set longer than the jitter window,
you're golden. Well, the trigger/output propogation delay has to be
shorter than the delay to first false transition...
For retriggerable monostables, the extra edges will stretch the output
pulse; if the stable time is guaranteed longer than the monostable
That introduces phase delay, of course, and senses some average over
the circuit.
similar approaches.
One channel for the positive edge processing. A timing action. One
channel for the negative edge processing. A timing action. Some cross
Let fuzz pass by.
Let fuzz pass by.
neg edge.
datasheet.
D from BC
It's not that.
It's to clean up the output of a comparator in my app. The comparator is
getting a damped ring signal due to some unavoidable inductor resonance.
Oh, I thought you wanted some debouncing.
You don't want debouncing. You want damping.
Damping "inductor resonance" is the same as properly terminating a TL.
It'll cost you one resistance and maybe an additional cap. Nothing more.
And damping the resonant circuit will give you the fastest clean response.
I've maxed out the amount of hysteresis I can put on the comparator. All
this is in a main feedback loop and the debounce cct has to be low delay
to enable the highest system frequency. The higher the frequency in my
Yes, why make it simple when you can make it difficult.
F
Fred Bloggs
jitter.
jitter.
the circuit.
similar approaches.
Let fuzz pass by.
Let fuzz pass by.
neg edge.
datasheet.
D from BC
It's not that.
inductor resonance.
D from BC
You're wasting everyone's time with your partial description of the
circuit and signal source. All those FF and OS circuits are unnecessary.
At the least , it is a simple matter to employ ac positive feedback to
the comparator to coast the output through a 100ns ring down time, and
then only if for some reason the "inductor resonance" itself cannot be
over damped using any one of the numerous techniques to do so. Is this
"resonance" due to a length of uncontrolled impedance *wire* running
from the nebulous 'power section' to your add-on board? If so, a simple
series small resistor goes a long way towards damping a high frequency
resonance ( ~100MHz in your case ) while preserving more than sufficient
BW for the processing. SHEESH!
John Fields
