Debouncing....at About 1Mhz
John Larkin
I think you guys (JF and JL) are making things to
complicated. At first I though a Flip-Flop was needed
but now I think a single OR gate with a Cap will do
it, as I posted.
Cheap, simple, and fail proof. It "triggers" on the
1st detection of a Hi, so it's fast, then latchs up
for a period decided by the Cap value, and ignores
the rest and then automatically resets.
Regards
Ken
That cleans the input rising edge but propagates all the falling-edge
glitches. I don't think that's compatible with D's first-post
requirements. The output falling edge will be nasty, too, which is
fixable with another resistor.
John
K
Ken S. Tucker
glitches.
No it does not. The OR gate locks up to a
hard Hi O/P 1 then when the O/P goes to
Lo the gate gets a hard "0" via the feed-back
Cap.
John
The OP revised his conditions, and said bounce
settles in a fixed time, that my circuit will adjust
to by a variation of the Cap.
Any logarithmic ringing below the Hi threshhold
is ignored, (~ 2/3 Vcc).
Regards
Ken
John Larkin
Cap.
But it's an OR gate.
CRAP .or. 0 = CRAP
John
John Fields
it, as I posted.
JosephKK
D from BC [email protected] posted to sci.electronics.design:
Ok..if I hairballize your circuit a bit :)
D from BC
OK here is my suggestion:
5k
20 pF || ___
.-||-o-----|___|- 5v
__ .-o-----. __
gnd --\ \| .-------------------| \
| | | | )o-
o--------o/__/| | .---|__/ | __
| | | | | )o-----o
| 9602 | )---------------)---' '--|__/ |
| '--o----' | | | |
| | | | X
| 5k | | | __ |
| 20 pF || ___ | | '--| \ |
| .-||-.-----|___|- 5v | | | )o--'
| | || | | | '-----|__/
| __ .-------. | | |
'----\ \| | __ | | |
| | o-------| \ | | |
5v --o/__/| | | )o--)---)--------'
| | .--|__/ | |
9602 | '----)----------' |
'--o----' | |
----------o--------------'
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
Now if someone wants to breadboard it or simulate it in spice i would
like to see the results.
Jim Thompson
5k
20 pF || ___
__ .-o-----. __
| | | | )o-
| | | | | )o-----o
| '--o----' | | | |
| | | | X
| 5k | | | __ |
| | || | | | '-----|__/
| __ .-------. | | |
| | o-------| \ | | |
| | .--|__/ | |
'--o----' | |
That's the classic approach. IIRC there is a version that somehow
gets both positive and negative edge triggers from a single 9602.
I also don't know if the 9602 can handle the fast edges that "D from
BC" mentions.
...Jim Thompson
D from BC
BC" mentions.
...Jim Thompson
The lower the tp ...the more I can increase the frequency in my app.
<10nS might be getting exotic but I can accept delays up to an
absolute max of 100nS.
But around 100nS...it's just ho-hum.. Yawn :O
But ...in the 10nS neighborhood..things get exciting. :)
That's probably why I posted <10nS instead of posting (<100nS).
D from BC
Jim Thompson
D from BC
I suspect the cleanest approach would be two D-flops that catch the
first occurrence of a transition (positive or negative) and cross-lock
in some fashion to accomplish the "blanking interval"... neither one
having to try to follow the vigorous ringing.
...Jim Thompson
John Larkin
5k
20 pF || ___
__ .-o-----. __
| | | | )o-
| | | | | )o-----o
| '--o----' | | | |
| | | | X
| 5k | | | __ |
| | || | | | '-----|__/
| __ .-------. | | |
| | o-------| \ | | |
| | .--|__/ | |
'--o----' | |
A fast input spike can fire both one-shots! Then the fun begins.
John
D from BC
5k
20 pF || ___
__ .-o-----. __
| | | | )o-
| | | | | )o-----o
| '--o----' | | | |
| | | | X
| 5k | | | __ |
| | || | | | '-----|__/
| __ .-------. | | |
| | o-------| \ | | |
| | .--|__/ | |
'--o----' | |
If I have this right...
4 device delays for neg edge.
4 device delays for pos edge.
IIRC, the JL cct only has a 2 device delay.
D from BC
Jim Thompson
This has got to be a classic signal clean up problem....
I need a circuit that triggers on edge A, then ignores about 0.1uS of
jitter then triggers on edge B and then ignores a following 0.1uS of
jitter.
In | | | | | | | | | |
A | | | | B | | | |
|<0.1uS>| |<0.1uS >|
|< 0.5uS >|
Out +------------------------+
A' B'
Edge A to A' is ~ less than 10nS
Edge B to B' is ~ less than 10nS
All values are approximates.
"In" and "Out" are repeating waveforms.
I think I can do it with:
1 flip flop
1 >0.1us delay circuit
Sprinkled with gates..
Or maybe I need 2 flip flops..one for edge A and one for edge B..
I'm not even sure yet which type of FF to get.
If anybody has done this problem before and doesn't mind sharing..let
me know a topology...
In the meantime, I'll be doodling until I get a solution...
D from BC
My thoughts....
http://www.analog-innovations.com/SED/AlternatingEdge.pdf
make a flip-flop that can alternately be positive- or negative-edge
triggered, by adding XOR in front of clock input and tying one XOR
input back to output.
BUT... DELAY switch-over to avoid racing.
My 74HC74 model indicates it can't cope with 20ns/20ns noise, so
faster logic is needed.
Timings, etc., for illustration only... squeeze to fit ;-)
...Jim Thompson
D from BC
My thoughts....
...Jim Thompson
Hey... that looks good. :)
It looks like a hairballized spin off of JFs circuit.
Still with 2 gate tp. Impressive.... :)
One detail I'm wondering about...
You have Pre and Clr connected together for a system reset.
Shouldn't one or the other be used..Not both..
D from BC
Jim Thompson
D from BC
Yep, Just spotted that myself ;-)
...Jim Thompson
John Larkin
My thoughts....
...Jim Thompson
I think you can eliminate the HC04 by using Qbar of the ff.
John
John Larkin
...Jim Thompson
Actually, just pull them high. There's really no powerup preference
for either state.
John
Jim Thompson
John
I don't know. BOTH the clock flip AND the D-input need delay...
otherwise SUAH timings are violated and the 74HC74 has "arrhythmia"
...Jim Thompson
Jim Thompson
for either state.
John
It's only a simulation convenience.
...Jim Thompson
JosephKK
John Larkin [email protected] posted to
Fred Bartoli [email protected] posted to
[snip]
Just do it in a modern CPLD, and 10nsec should be easy. Though
there's a bit of overhead getting started in CPLDs, it's cool
that when you make a mistake in your logic or see some
improvement, it's just a re-route.
For logic (if you are willing to get away from your SN7474 and
SN7486
parts...), you could use LVC parts at 5 volts. They're fast.
Cheers,
Tom
Thanks for the headsup for the future.
Did a quick read on
http://en.wikipedia.org/wiki/CPLD
:O .ohhhh that looks scary...
Is CPLD work more complicated than programming microcontrollers
with assembly?
D from BC
No, not really, just different.
When I was a kid I did program 6800/6809 in hexa (no assembler
available). Well one of my first tasks was writing a line editor
and an assembler, all that in hexa.
I certainly would not do that for CPLDs.
OW. That is ugly and painful just to think of.
The original Signetics PLAs were programmed by marking Xs on a form
to indicate where to blow fuses. It wasn't all that bad.
I think one could program a PAL or even a 22V10 at the fuse level
without extreme agony, although there are easier ways to do it.
John
Though i did not design it that way, i could certainly translate the
design into the fuse patterns at the time. I expect i could still do
it today. Not that i would want to.
K
Ken S. Tucker
Input ------>
OR ====> o/p
|__________ |
cap
ground
Regards
Ken
