Decision making before micro processors
harsh2
Jul 29, 2004
90
i need a circuit to turn a relay on and off.
the relay controls 12 volt fans.
the control condition is heat, which comes from my refrigerator, and the fans vent the heat away from the cooling fins.
so when frige comes on i would like to have the fans come on shortly thereafter.
and when the frige goes off i would like to have the fans go off.
i could even do it without a processor using an a/d converter, but i dont even want to use an a/d converter, seems like overkill.
the circuit should be simple , maybe using an op-amp ,maybe.
options:
thermistor with changing resistance..
but how do i turn a changing resistence into what i need ?
driveing the relay isnt a problem assuming i have a signal to drive it with.
so i have a changing resistance ,and i am working with 12 volts i think the relay is 12 volts also
Thank you.
william
harsh2
Jul 29, 2004
90
thats exactly what i was looking for ;D
i cant read whats written under the circuit :(
the mic-502 is an op amp?
MP1
Dec 7, 2003
3,399
Here is the data sheet for the MIC502 in case anyone needs it. Also has a nice clear diagram in the data sheet for application.
MP
mic502.pdf
  • mic502.pdf
harsh2
Jul 29, 2004
90
i decided to try a comaprator .. the LM339 quad comparator..
and it worked *yay*.. and is working as we speek.
harsh2
Jul 29, 2004
90
all parts can be gotten at radio shack..
PART LIST
1) Thermistor
1) LM339 Quad Comparitor
1) IFR 510 Mosfet transistor N channel
1) 10K varible resistor
1) 10K resistor
2)330K resistors
1)2.2K resistor
ante1
Jan 24, 2004
4,138
harsh,
A suggestion, if you add some positive feedback you get a Schmitt trigger effect and a better on/off switch.
Ante ::)
ante1
Jan 24, 2004
4,138
harsh,
This is what I am talking about: http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/schmitt.html
Ante ::)
