Dell Optiplex SX260 Computer Won't Boot Up
I have a Dell Optiplex SX260 small desktop type computer that won't
boot up. When I press the power button, there is no display on monitor, no
HDD spin up noise. The only "life" I see/hear is the power light comes on and
the fans run. I tried a bootable CD, but the CD drive doesn't "run".
Note: I protected against static damage using a ground strap to my body.
I checked all the on board fuses (all good), solder joints, and power
supply output voltages with a load. The CMOS (RTC) battery is good.
I even removed and reinstalled the CPU.
Did anyone have the same problem with this model computer?
Thank You in advance, John
Ron
Hi, I have a Dell Optiplex SX260 small desktop type computer that won't boot up. When I press the power button, there is no display on monitor, no HDD spin up noise. The only "life" I see/hear is the power light comes on and the fans run. I tried a bootable CD, but the CD drive doesn't "run". Note: I protected against static damage using a ground strap to my body. I checked all the on board fuses (all good), solder joints, and power supply output voltages with a load. The CMOS (RTC) battery is good. I even removed andreinstalled the CPU. Did anyone have the same problem with this model computer? Thank You in advance, John
I think that instead of thinking about this as a Dell computer problem, you might look at the problem as what would cause *any* desktop to not boot. It's been a long while since I've knocked together desktop computers, but when one didn't boot it was because of simple things like conflicting cards,or even a
keyboard problem. Checkout this
http://pcsupport.about.com/od/findbysymptom/tp/computer-wont-turn-on.htm
for some really good troubleshooting tips.
Ron
HDD spin up noise. The only "life" I see/hear is the power light comes onand
Many Dell Pentium 4 motherboards contain bad Nichicon brand capacitors because Nichicon goofed up the production of models HM(M) and HN(M) from about 2002-2004. The date codes are in the form LYYMM, where L is a letter, YY = last 2 digits of the year, and MM = week of the year. So H0324 meansthe year 2003, week #24. 4-5 of those capacitors are 1500uF, 6.3V, 10mm diameter and located around the DIMM sockets and AGP socket. Behind the CPUare about ten 1800uF, 6.3V, 8mm caps and another 3-4 1800uF, 16V, 10mm caps on the other side of the MOSFET heatsink. Those may be Rubycon brand (big "K" stamped in the tops) model MBZ or MCZ instead of Nichicon (big "+" stamped into tops). The Rubycons were never defective, but TheCapKing.com says the Pentium4 was so power hungry that even those caps can go bad in 5 years. Most caps in motherboards can't be tested with an ESR meter except by unsoldering them because so many are in parallel.
Some people replace conventional wet electrolytic caps with dry solid polymer caps, which are more durable in heat. Here's some information about doing that:
http://www.badcaps.net/forum/showthread.php?t=4969&highlight=gx-270
BadCaps.net not only has a great deal of information but also sells high quality caps.
Be careful about counterfeit caps. DealExtreme has sold them, some being pretty obvious fakes (Teapo brans substituted from Sanyo or Nichicon), and apparently only one Ebay dealer sells only genuine caps:
http://stores.ebay.com/PC-MotherBoard-Capacitors-Store
