73's de Edd
- Aug 21, 2015
- 3,730
- Joined
- Aug 21, 2015
- Messages
- 3,730
Sir Michael . . . . .
O.K. here I have the two power supplies initial prep work, with its added annotations of your initially mentioned areas of testing.
You say . . . .
Regarding the REG_CNT (p.110), there are five Full Wave Rectifier Ccts. on this pcb which is attached by Edge Connectors to the REGULATOR B'D.
Still (on p,110) I have a 'TaggedTestTail' on CN101 (pin1)+8V. This reads +10.78V.
No problem on that high of a voltage level as that is actually being the initial RAW DC supply voltage from which the + 8 VDC is to be derived from AFTER it comes out from the IC106 . . . a 7808 linear regulator.
Next, (on p.111) 'SIDE CONNECTOR' a 'TaggedTestTail' on CN14 (pin14) +8V.
This reads +4.589V. My readings are taken with a UNI-T UT61E dvm.
Now that present voltage IS supposed to be a now regulated + 8VDC level and not the +4.589V VDC which you are reading.
That now poses the question, is that a faulty IC106 regulator or is it from loading downstream upon this supply line pulling it down to this present reduced output level?
You may notice some skips in your manual, relevant to schematic pages, this one below actually shows the linear supply's portions massive transformer, and its circuitry as well as the SMPS.
You can see that the SMPS feeds a . . . whole pitshot . . . . of minor supplies that are further divided down and derived from its basic / sole 5VDC output.
I suggest that only the +8VDC regulator is left working and having the feeds to the other boards*** disconnected and then see if the +8VDC is up to full voltage and then start adding on the other branched out supplies from this source to see which one is pulling it down.
***Connector CP13A Pin 7
*** Connector CP5 Pins 11 & 12
*** Connector CN403 Pins 9 & 10
Thasssssssit . . .for now . . . .
POWER SUPPLIES BASIC SCHEMATIC . . .
Touch points . . .
As is seen after the unit has AC power from the wall outlet, this units SWITCH MODE power supply is active 48 hrs per day, with its ~ +5VDC output.
Also it feeds the YELLOW box power relay to activate AC power to the upper linear supply transformer primary, IF there is a logic HI from the units uP to feed to the base of the relay driver transistor, located just below the relay.
73's de Edd
You say . . . .
Touch points . . .
73's de Edd
