F
frank1492
- Jan 1, 1970
- 0
I am back! Thanks again to all of you who made suggestions
when I had difficulties with my LX-201. It turned out that it was
indeed the transducer itself!
Although I considered many solution alternatives (with your
help) I finally settled on trying an Airmar P79 in-hull transducer
because they told me it would be compatible with the LX-201.
Also, I preferred not to mess with the old thru-hull as it needed to
be pulled from the bottom and appeared to be epoxyed in place.
Initial tests have shown that the Airmar will work well as it
will be used on a non-cored Grady White with a solid hull thickness
of less than one inch.
The problem has been the mounting of the transducer. Airmar
uses a bottomless base with a flange that is secured to the
inside of the hull with adhesive. The base is then filled with either
mineral oil or propylene glycol (their instructions), and the
transducer snaps on over that such that its bottom face "floats" on
the liquid. Obviously whatever adhesive is used must make a permanent
seal between the hull and the base flange as the base itself has no
bottom.
Here is the problem. Airmar specifically states that epoxy,
or the previously recommended Boatlife LIfe Seal or 3M 4200
are *not* to be used. Only GE Silicone II is allowed! With an area
perfectly cleaned with 409 (the area has a gloss), I have tried to
mount the base three times, each with many hours of cure time.
Each time when I have added the glycol, it leaks out after a few
seconds as if it were reacting with the silicone. When the base is
removed, the silicone on the flange is a sticky mess.
It really doesn't make sense to me that silicone would work at
all in this application. So why not use epoxy? Is it just that it
would be permanent and if the transducer base had to be
moved or removed you couldnt get it off? Surely Airmar sells
replacement bases. (I will check tomorrow.)
Your counsel is much appreciated. Am I just doing something
wrong in applying the Silicone II? (Otherwise known as "Kitchen
and Bath.") Or am I correct that this is a bad idea for a permanent
installation and epoxy should be used?
Thank you.
Frank
bottom.
Thank you.
Frank
