Derate 300W amp for SW?
Louis Robson
I have a JBL BP 300 mono subwoofer amp (300W) that I would like to
feed with a continous sinewave within the spec. range of the unit
which is 10-320Hz.
What is the rule of thumb for derating the wattage where this type of
use is concerned.
I assume I then would put a suitably rated power resistor in series
with the woofer.
Regards,
Louis Robson
Phil Allison
"Louis Robson"
which is 10-320Hz.
** The BP300 is a car audio product, 12 volt supply & SMPS.
use is concerned.
** Rules of thumb are no use to you.
Only testing will show how long it can hold up at 300 watts .
with the woofer.
** Then you assume wrongly.
Woofer impedance is non simple function of frequency.
.......... Phil
Rich, Under the Affluence
which is 10-320Hz.
use is concerned.
with the woofer.
Egads! Sounds like a freakin' earthquake simulator! What is it that
you're trying to accomplish?
Rich
Jon Danniken
Annoy everybody who is sitting peacefully in their homes and minding their
own business in a six block radius; that's my guess.
People who operate these "thumper cars" need to be shot.
Jon
F
Fred Bloggs
which is 10-320Hz.
use is concerned.
There is no rule of thumb- that 300W rating is a "music power" rating
with underlying assumptions about what percentage of the power lies
within the 10-320Hz band, and that will be far less than 300W. Contact
the manufacturer and ask for the "continuous power" limit.
with the woofer.
That's one way to do it.
René
which is 10-320Hz.
use is concerned.
with the woofer.
Regards,
Louis Robson
Better use this:
http://www.eminent-tech.com/howitworks.htm
Or build one yourself using a RC helicopter collective pitch control
system :)
W
Walter Harley
which is 10-320Hz.
use is concerned.
It's a switching amp, so the output stage is probably not going to get much
hotter at full power than at low power.
Since it is rated at 300W into 2 ohms (or 150W into 4 ohms), the supply
rails must be considerably higher than 12V; it is powered from 12V, so the
power supply itself must be a DC-DC converter, presumably also switching.
Therefore, you probably don't have to derate for continuous sinewave
operation in the same way you would a class-AB amplifier or linear power
supply. But you do need to derate for your load impedance - the higher the
load, the less power will be delivered, since the constant here is the
supply rail voltage.
with the woofer.
That assumption is incorrect unless you are trying to do something peculiar.
What is it that you are trying to accomplish?
Phil Allison
"Walter Harley"
** How do you know ?
Seems to have a lot of heastsink area for one of them.
The JBL site says it has a SMPS.
.......... Phil
Pig Bladder
Wow, $13k. No amp, no cross-over. (I suppose some might consider this
cheap?)
****, man, if peple have that much money to spend on noisemakers, please
let them know I'll give them a bl-w j-b for only $1000.00.
