Design analog wave generator
alireza1
Mar 21, 2004
98
Hi everyone
I want to build an analog circuit that consists of 4 parts.
Part1 is a simple adjustable square wave
Part2 changes the duty cycle of the wave generated from Part1.
Part3 shifts the phase of the wave generated from Part1.
Part4 changes the duty cycle of the wave generated from Part3.
I need two signals from this circuit:
Signal1 from Part2
Signal1 from Part4
it is clear that I need four potentiometers for adjusting in all the parts.
Can anyone suggest a simple circuit for the blocks?
audioguru2
Apr 6, 2004
12,022
A square or rectangular wave has a fundamental plus many harmonic frequencies. It is simple to change the phase of one frequency but difficult (a time delay is needed) for many frequencies. Maybe a microcontroller and somebody to program it can be used.
alireza1
Mar 21, 2004
98
Thank you audioguru
using microcontrollers is the best answer, but I want to use analog circuit.
JanHalsey
Jun 9, 2016
Hi everyone..as per my experience you can easily do this with the implemented circuits. There are many boards available which can work as a function generator and the other functions you can made using any Microcontroller and the ADC and DAC circuit. Use simple components like Op-amp and oscillators. A square or rectangular wave has a fundamental plus many harmonic frequencies. It is simple to change the phase of one frequency but difficult for many frequencies.
turnkey pcb assembly
