erique82
- Jan 1, 1970
- 0
Hi, i'm wondering if anyone here has ever attempted/successfully
designed a rangefinder? i'm designing one currently based on phase
measurement, but i'm just not so sure if it will work out. I greatly
appreciate ideas and suggestions . My questions are:
1. is it ok to use a normal laser pointer as a transmitter? if i do
need to modulate it, then to what frequency should i modulate it to as
so an electronic receiver circuit can detect it?
2. i'll be using two APD photodiodes as detectors. One for the
transmitted wave, the other for the received wave. The original laser
beam is splitted by a splitter, of course. my question is... is this
method ok?
3. can i use a pll to compare these two phases (output from the
receiver circuits) and then use a microcontroller to calculate the
distance? or should i use a normal oscilloscope?
any other simple designs or suggestions? i'd appreciate if anyone could
share a circuit diagram with me. thanx
method ok?
