Desoldering Stations
Chris F.
Can anyone recommend a good used desoldering station? I've been looking
around on places like Ebay, and it seems even used ones can be pretty
expensive. Weller, Pace, and Hakko seem to be the predominant brand names.
I basically need something for general electronics - TV's, VCRs, etc.
Something that can easily desolder a 64-pin IC, for example. I've been using
a desoldering wick for years, it works but the stuff is rather expensive
(and hard on the fingertips sometimes). I don't do any surface-mount work so
I wouldn't need anything for that.
Thanks for any advice.
TimPerry
for occasional use a small shop vac block the intake and insert a vinyl hose
from the hardware store.
get a cheap mechanical vacuum sucker and drill a hole in the side. glue in
the hose. add a cotton ball in the body of the sucker to prevent solder from
gumming up the tube.
add a footswitch to the vac for a final touch.
of course with this system you melt the solder with your regular soldering
pencil then apply the suction.
James T. White
Chris,
I'd have to recommend Hakko and recommend against Weller. No real experience
with Pace stuff.
O
Ol' Duffer
with Pace stuff.
I've had good luck with Pace, but no experience with Hakko.
Ditto thumbs down on Weller. They used to make good stuff,
but when the Cooper group took over, they instituted a flurry
of cost cutting that reduced most of their products to junk.
N
NSM
I still like the iron with the bulb on top, but for big IC's I'd go with an
iron with a selection of tips that size.
My 2 cents.
N
David Gersic
I have a Hakko and like it. Picked it up used on eBay relatively cheap
a while ago. Had to get some parts for it, though, as it was not complete.
That probably helped the price.
Flea markets may be better shopping for you, if you're looking for used.
eBay tends to draw higher prices than local, if you can find somebody
selling local that isn't asking eBay prices. Or, if you can find a place
that deals in used gear, they may have a better price than you'll find
on-line, and with the benefit of getting to see the thing before you
buy it.
They all do one pin at a time...
A friend of mine has some recommendations on:
http://www.marvin3m.com/begin/index.htm
The Xytronic ($100) or MPJA sound like good prices, but the Tenma
($250 on sale) is probably your best bet if you're buying new.
I used the cheap Radio Shack sucker for a few years, and for being a
$15 tool it works pretty well. It's not a _good_ tool, but it's
surprisingly good for what you pay for it.
Whatever you get, remember that it has consumable parts (filters, etc.),
and be sure that you get some spares, and that you'll be able to get
spares in the future. Depending on the design, see if you can get a
spare filter tube for it, so that when it fills up, you can swap in a
fresh one while the full one cools. Emptying out a full, hot, filter
tube while you're working kinda sucks.
Jeff Walther
If you want really cheap, get a heat gun with adjustable temperature and
some modeling clay.
Cover the surrounding components with modeling clay (so they don't blow
away), set the heat gun to about 600F and apply to the target component
until the solder melts and the components can be easily lifted or its pins
pushed out of their holes. I use a dental pick to test the solder every
few seconds to see if it's soft yet.
This is not the most component friendly method, but I've been using it on
home projects for several years, with very few failures.
I've removed things as simple as 32 pin DIPs and as complex as 208 pin QFPs.
For clean-up afterwards you may still need braid. But with the component
removed you can use a wider braid (higher capacity per inch) and more
powered soldering pencil and the braid's price seems to be constant per
length regardless of width. Cleaning through-holes will be easier with
the pins removed and can be done with the various air methods mentioned by
others.
N
N Cook
some modeling clay.
others.
I can second that, used the following today to remove a 32 pinner
but most often use it for salvaging ICs before discarding rest.
No troubles with over-heating of the salvaged ICs.
Just to emphasise practise on an old board of TTL or such
before using for repair.
I own an old Pace, i think, de-solderer but last time i used it
was perhaps 3 years ago. The great advantage of the following is
you're pulling from the other side and it is very rare to dislodge
a solder pad/trace and extremely quick and cheap.
Other tips on
http://homepages.tcp.co.uk/~diverse/
De-soldering ICs
Use a hot-air paint-stripper,1400W,500 degree centigrade,with 2 level heat
control to prolong element life. Activity may appear fearsome but it is no
worse than a flow-solder bath.Pre-heat for one minute then apply to
pcb,make
extractor tool to pull ic from component side. Make an IC extractor from an
old large pair,10 inch, of
circlip pliers,the jaws need to open out enough to clip around the ends of
up to 64 pin
ICs with enough force to overcome the mechanical force of the situation
where all
the pins are angled relative to the PCB holes.Forge around both of the
original circlip
pins,one joggle at right angle to clear the heigth of the ICs and a slight
inwards joggle
to make purchase on the underside of the IC,grinding a wedge angle to the
points
helps particularly where there is no clearance between IC and pcb.
[ Because of these joggles this tool is also useful for depressing the rear
grippers
and releasing of that type chassis mount fuseholders and switches when
internally surrounded by other
components ]
Use this technique for salvaging (working order) up to 64 pin ics ( when
practised ),other
components, sm and even repair (tracks are not dislodged).For repair work
beware of
spatter of molten solder causing solder bridges on adjascent compoents
because if you
are doing the job properly,ie not dislodging pcb tracks the IC must be
pulled out with
some force and the board tends to flex so possibility of flicking solder.
The secret is to be as quick as possible,idealy the body of the extracted ic
will
be just about handleable rather than too hot to touch.Try practising on a
board
with close packed TTL chips or similar and aim for an extraction rate of
something like one every 2 seconds.Between boards keep the hot air gun
running on
low power setting (not switching off).Don't rest the gun against the board
when heating
as vibration seems to affect the element life also don't allow the board to
flex back onto the gun for the same reason.Hold the gun so airflow is angled
to the board
as solder spat directly into the nozzle can kill the element.
About the only components that cannot be removed with this technique are
parts
moulded in soft plastic,e.g. crystal sockets,rf coils with plastic former
(IF coils usually OK)
some DIP switches. Even these are desolderable intact if the body of the
component is previously
cooled with a blast of aerosol freezer spray.
SAFETY NOTE:- ensure good ventilation, use safety goggles because trapped
water etc in the capaillary structure of glass fibre reinfiorced PCB can
super-
heat to steam and jet out molten solder,also it is possible to overlook
small
electrolytic capacitors on the solder side of the board which of coarse
explode
with the direct heat of the hot air gun and beware of very
slight risk of combustion of adjascent flammable parts especially where
components have extra (un-noticed) mechanical bonding leading to extended
duration of heating activity.
Hint for de-soldering surface mount ICs.
Form a ring of silicone covered wire around the IC{to isolate the remaing
components on the pcb.Push a thin piece of wire
under one side of the IC and form a loop around the IC,repeat on the other
side;this is to remove the IC when the solder melts, tug on these wires
while
heating up to ensure minimum heating contact time.
Place a slab of PTFE with right size hole cut into and
clip pcb and slab together with clothes pegs/Bulldog clips etc.
If the IC is for re-use then cover body of IC with heat insulating material
or blast IC with freezer spray.Allow the hot-air gun to get up to heat{say 1
minute}
before applying to IC.
For more crowded boards make "conical" shrouds to surround the IC. I used
some PTFE strip that i had but thin paxolin or similar but drilled and wired
together would probably do. Cut 4 small trapezoids from the PTFE strip.
Fixed together with all long edges one side and short edges adjascent on the
other side. Fixed together with paper staples but for the smallest shroud
for 8 pin SM had to wire together the final join. Forms a sort of truncated
cone in shape. Tie to the PTFE cone (to stop the blower blowing it off) with
copper wire or temporarily solder to distant points.
When practised the heated contact time should be less than
2 seconds - no board distortion or collateral damage surprisingly.
If you can't get the tugging wires under the IC then pass
under a few pins at each corner.
Because this tugging frees the IC at the earliest moment, the solder
on the board is not fully melted and leaves a profile for localising
the new IC in place and then solder pin by pin.
SAFETY NOTE:- ensure good ventilation, use safety goggles,and beware of very
slight risk of combustion.
Chris F.
One other little question - is there any advantage to "pulse-vaccuum"
systems?
M.Joshi
I don't know if this question is relevant here but is a de-solder wic
better and easier to use than a de-solder pump? I haven't had muc
luck using a de-solder wick. They seem to just get clogged and you en
up putting the solder back on the connection instead of removing it.
Am I not using it correctly?
James T. White
M.Joshi said:
I don't know if this question is relevant here but is a de-solder wick
better and easier to use than a de-solder pump? I haven't had much
luck using a de-solder wick. They seem to just get clogged and you end
You might find that adding some solder flux makes the wick pull the solder off
the connection much better. When the end of the braid gets tinned with solder,
it's time to cut it off and start with clean wick end and more flux. Going
through lots of solder wick is a down side of this method.
