K
Kieran Simkin
- Jan 1, 1970
- 0
Hi Guys,
I'm trying to build a simple project to get some pratice in analog
electronics. The intention is to make an electronic cat flap that only
allows entry to a cat wearing a magnetic collar (yes, you've seen them in
pet shops).
I a 403Ohm coil around the entrance to the cat flap, passing a magnet
through this coil generates approximately 1-20mV and varies the resitance of
the coil by about 20Ohms in either direction. I need to turn this signal
into a digital on or off, with on indicating that a magnet is moving through
the coil. I'm not concerned about directionality, and the more sensitivity I
can get the better. Neither does the signal need to remain on for very long,
as I have a latching circuit in place that will work with a very short
signal from the detector.
I attempted to built an A.C. coupled darlington pair as described on the
following page (following the resistor and capacitor values exactly):
http://www.talkingelectronics.com/Projects/Inductor/Inductor-3.html
However, this did not work as the output remained on in every instance.
Measuring the coil and the 22nF capacitor in series gave me a resistance of
infinity - I don't know why because I'm not quite sure of the function of
the capacitor in this circuit.
I tried removing the coil+capacitor pair and replaced it with a normal
potential divide with the coil on one side and a fixed resistor and a preset
on the other side of the divide. Even with the resistance on either side of
the divide matched, I'm still unable to get any negative output from the
circuit.
Can somebody point me in the direction of a circuit that should work for my
project? I'm not sure whether I should be using a darlington pair or an
op-amp, or whether I need to A.C. couple the coil to the collector in my
first transistor, if so, I'm unsure of the reason for A.C. coupling and I'm
also unsure of why it does not work for me.
I've tried doing a search of the internet but cannot find anything more than
a basic description of a darlington pair and how to wire one to an LDR,
presumably a coil is significantly different to an LDR?
Any advice you guys could give me would be greatly appreciated.
Best regards,
~Kieran Simkin
Digital Crocus
http://digital-crocus.com/
pet shops).
circuit.
Best regards,
~Kieran Simkin
Digital Crocus
