Jeroen Belleman
- Jan 1, 1970
- 0
I'm trying to find a way to detect tiny pulses following a very
large one. I have this beam current transformer sitting in a
particle accelerator, delivering 4ns, 600V pulses in response to
the passage of the main bunch of particles. This bunch fills
one of a continuous sequence of 'RF buckets', while the others
should be empty. In practice, a tiny bit of beam, on the order of
1e-5 times the main beam, leaks into adjacent buckets, and this
bothers the LHC.
If I attenuate down far enough to protect the digitizer's input,
there is no hope of seeing any of this tiny spill, so I must
clip the main pulse and spare the small stuff. The RF buckets
are at 80 MHz, so the clipper must recover fast. To preserve
the 3GHz bandwidth of the signal, it must be a low capacitance
device too. Small enough to hide it by necking down a 50 Ohm
stripline, for example.
I've dabbled a bit with various combinations of attenuators
and Schottky or ESD protection diodes in Spice, and it doesn't
look straight-forward. I'd be abusing the diodes badly, far
exceeding their maximum current. Beefier diodes are slow and
have too much capacitance.
Anyone here wants to share some wisdom?
Jeroen Belleman
bothers the LHC.
Jeroen Belleman
