Device powered by computer usb port but not USB phone charger (U-phoria UM2)
jh_bach
Jan 14, 2021
Hello, just joined to the forum because I was looking for a solution for same problem mterry highlighted. I have U-phoria UM2 and I want to use it without laptop, just need to connect to a powerbank because I'm just interested to mix 2 signals. What is the solution on mterry issue? I cannot found solution in the forum...
This post is moved from this old thread:
https://www.electronicspoint.com/fo...er-usb-port-but-not-usb-phone-charger.288982/
14,317
According to the manual the UM2 should work with a powerbank. Did you use the original Nitecore cable supplied? Does the UM2 work on a laptop but not on a powerbank?
Jarod997
Aug 4, 2021
10
I just posted on the original thread, but I'll recap here:
I bought a UM2 for a non-computer application not realizing that the device was *only* USB powered. It powers on when plugged into a computer, but not a wall charger.
I have a ticket in with Behringer, but so far no luck.
There may be a voltage divider hack on the D+ and D- pins on the USB line which will make the device power on, but I don't want to hack it yet if I don't have to. The other possibility is that the device will only power on after it receives a data packet from a USB controller (eg a computer).
*lightbulb* I just discovered my VoIP phone has a USB port which must have a controller in it, and it works to power on the UM2. This is significant evidence to support the USB Controller theory of how this thing is powered.
Back to @Harald's point, the Powerbank may have a USB Controller in it, whereas a "power block" (eg just a simple plug in the wall USB charger), even a 2A rated unit, doesn't - and won't power on the device.
Jarod997
Aug 4, 2021
10
So, for clarity, here's a brief list of what does and doesn't work.
Does:
  • Computer (Windows & Mac, desktop & laptop)
  • Yealink T46S VoIP Phone
Does Not:
  • UPC Surge Protect power bar
  • TPA-46050200UU - 2000 mAh USB wall charging "block"
Jarod997
Aug 4, 2021
10
So here's my last post about it. From what I've been able to figure out myself, this device is not a stand-alone pre-amp, it's a "sound card". It requires an OS to use it as an input and output sound device. (The two are separate, which is why there's a toggle on the front for "direct monitoring".)
In the end, it turns out I don't need to use a pre-amp - but I thought I'd publish my findings for others.
I hope it helps.
