dialup issues
  • Thread starter klem kedidelhopper
  • Start date
josephkk
How much would you like to bet? The ANAC, ANI, DAMT, quiet line,
milliwatt tone, etc test numbers vary between locations, CO's, type of
switch, and companies. Same with quiet line numbers, security, test
equipment, procedures, and standards. AT&T is fairly standardized
throughout the system. I don't have a clue what Verizon does as
everything I work with locally uses AT&T.
However, if you want numbers to abuse, this might help.
<http://www.tek-tips.com/viewthread.cfm?qid=583069>
It's 10 year old, but looks accurate.
Please send my winnings to the address below.
Thanks. You warned me that they vary.
K
klem kedidelhopper
The lady from telephone repair called me back this morning and told me
they will be coming out to my house tomorrow to do "some rewiring". I
asked if they'll need to get into my house to do this, (just to be
sure I knew what she was talking about) and she said no. I then asked
the 64,000 dollar question. "Will there be a charge for this"? And
again it was no. "They will be working on the wires on the road" I was
told. I'm assuming this means a different, (and hopefully better cable
pair). Interestingly she asked if I would be home. She said that
although I didn't have to be, there would be no way that the
technician would be able to tell if my dialup was improved unless we
plugged my laptop into the interface while he was there. I was
surprised that they would have no way to assess dialup capabilities of
a pots line. They must have to do this for DSL don't they? So why
couldn't they assess dialup? Lenny
Geoffrey S. Mendelson
Jeff said:
Whether the
installer actually knows how to use the tester is another horror
story. I've seen both extremes.
<http://www.jdsu.com/en-us/Test-and-...-z-product-list/Pages/hst-3000.aspx?rcode=hst>
I had a friend in the early 1970's who was a repair/install supervisor for
New Jersey Bell. If a new employee was able to tell if they could get a dial
tone by picking up the phone, they were assigned as repairmen.
The ones that could not were assigned as installers.
He always had far more installers than repairmen.
Geoff.
K
klem kedidelhopper
Geoff.
The telephone company came out and fixed the speed problem. The
repairman said that I have copper all the way to the CO now where I
hadn't before. I'm only two miles from the CO, so I can't imagine what
my line previously went through to get from my house to the CO, but
anyway that part of the problem is now resolved. The most common
connection speed I've noticed now since this upgrade has been 49.20KBS
with the slowest connection sometimes at 45.0KBS. So now I have to
figure out what's going on with the ISP.
For the most part there is improvement, however it seems that at times
even though it appears that I have a good connection it constantly
disconnects me from the server, or the little green circle, (Windows
7) turns and doesn't seem to go anywhere. This is frustrating because
it's hard to tell what's going on. Sometimes when this is happening
I'll click on the connection icon and see the data changing so it
seems to be working but aside from what it says that I'm connected at,
at what speed?
Can the connection speed change while you're connected? I've tried
different local access number and some seem to be a bit better than
others but this is very hard to properly assess too. I would like to
take this up with the ISP but I feel that I might need to be armed
with some more information though. I'm just not sure of what sort of
information that should be or where or how for that matter I can get
it. Lenny
K
klem kedidelhopper
Disable call waiting on your phone service.  On most services, it's
dial *70 before placing the call.  You can add it to your modem
dialing string.  After the call is over, call waiting returns to
normal.
Jeff Liebermann     [email protected]
150 Felker St #D    http://www.LearnByDestroying.com
Santa Cruz CA 95060http://802.11junk.com
Skype: JeffLiebermann     AE6KS    831-336-2558
We don't have call waiting or any other services like that that would
upset the line. What else could it be that I could suggest to the ISP?
Lenny
