Differential Amplifier
Ungen
Aug 4, 2018
I have big problems understanding this problem. It's an earlier exams assignment.
I think my biggest problem is that I don't understand how the configuration on Q2 works. Looks for that the Q2 base get 0 volt..
Think a better translation on the last question might be " current source ".
Thanks in advance for any tips or solution.
Regards
Anders
LvW
Apr 12, 2014
604
I think, you have no other chance than to assume for both transistors a biasing DC voltage between base and emitter of Vbe=(0.65...0.7) volts. The exact voltage is not known and is not too important because of of the negative feedback effect of Re. Starting with such an assumption it shouldn`t be a problem fpr you to calculate the quiescent DC current through the transistors (can be assumed to be equal).
Kabelsalat
Jul 5, 2011
198
For the question D (the printed part not translated) it says that the 8.2kΩ resistor is switced by a current source.
btw. It's a bad practice not to labeling all components, as the resistors (that is to blame the assignment paper).
