Differential Output
Apparatus
I am using a Texas Instruments TLV320AIC1106 PCM Codec for some audio
circuitry. This codec is capable of driving an 8 to 32 ohm load
speaker. The suggested connection topology for this speaker is
differential output according to the datasheet, but a schematic is not
included with this recommendation.
I was planning to simply connect one terminal of the speaker to EAROUT+
and the other to EAROUT-, but recently it was suggested to me that in
addition I couple each terminal to ground with a 1kohm resistor. What
are the advantages of this?
Cheers,
Chris
Robert Baer
Apparatus said:
Cheers,
Chris
None.
W
Winfield Hill
Robert Baer wrote...
Correct. The purpose of a differential speaker output (often called
bridge mode output) is to eliminate the need for electrolytic output
capacitors when using a single-supply power source, and to double the
available speaker voltage, thereby quadrupling the maximum power
obtainable from the power source, which is often a small battery.
A bridge output is fully differential, and has no knowledge of, nor
need to interact with ground. Very small speaker amplifier ICs can
be made using class-D (switchmode) H-bridge output stages, which
dissipate little heat while driving the speaker. But it is necessary
to incorporate four power MOSFETs into the IC for the speaker current.
John Woodgate
I read in sci.electronics.design that Winfield Hill <hill_a@t_rowland-
Maybe the resistors are advisable if the loudspeaker can be
disconnected. Not to provide a load on the amplifier but to prevent
possible excessive centre-point offset.
Apparatus
Thank you all for your informative answers. The speaker is
disconnectable (headphones via phonojack), but the initial center point
offset should only induce a click or pop sound in the headphones. Since
this is not a problem, I'll leave out the resistors.
Cheers,
Chris
W
Winfield Hill
Apparatus wrote...
center point offset should only induce a click or pop sound
in the headphones. Since this is not a problem, I'll leave
out the resistors.
I don't understand your comment about center-point offset.
In these balanced amplifiers, both outputs are at the same
voltage with no signal, so the difference voltage is zero,
and plugging in a headphone should not make a click. Note,
the outer ring of the headphone jack shouldn't be grounded!
John Woodgate
I read in sci.electronics.design that Apparatus
Are you sure? There are two aspects:
1. The offset may damage the chip over time;
2. The click may exceed the 'acoustic shock' limits. People tend to put
the headphones on and then plug them in. Since many headphones produce
100 dB SPL for 1 mW or less input, the possibility of getting more than
126 dB SPL (the ITU recommended limit) is significant. I have
experienced a 126 dB click and I assure you it is VERY unpleasant.
F
Frank Bemelman
"John Woodgate" <[email protected]> schreef in bericht
[snip]
Playing Russian Roulette can be worse <G>.
John Woodgate
Well, theoretically zero. What actually happens depends on the circuit
configuration and the device characteristics.
Allan Herriman
John, which ITU recommendation is that?
Thanks.
Allan
John Woodgate
I read in sci.electronics.design that Allan Herriman <allan.herriman.hat
[email protected]> wrote (in <9g2qr0dl5q244i2c7vtn3l7jggjek4ou
[email protected]>) about 'Differential Output', on Mon, 13 Dec 2004:
The 126 dB limit for clicks was applied in UK at the time of de-
regulation, and I am not sure where it came from. The ITU document is
P360, and I don't have a copy of it. The predecessor had 135 dB for very
short clicks and 125 dB for longer disturbances.
