digital camera repair.
Jose Capco
I have a Canon powershot digital camera and I opened it because I was
suspecting the CCD sensor (the LCD display was showing me dashed lines
instead of the actual display). After opening it, I decided to leave
it aside as the work would take more than my available time. But then,
the camera wouldnt turn on again.. even after I used newly charge
batteries and power supply to bring it back to life.
Does anyone has experience in camera repair? Does anyone have an idea
what could be the problem here? I really don't see how Im able to
check for current running in a camera.. and cameras dont usually come
with schematics. If I want to get to the board I need to open it even
more than I just did before and I am afraid it could get worst.
Sincerely,
Jose Capco
Michael Black
If you're worried about doing damage, then don't do it. Take it to
someone who can do the repair.
The unskilled should never deal with a piece of electronic equipment
until they've reached the point where they've decided it's not worth
paying to have repaired, and are about to toss out the thing. Then,
it becomes viable for the unskilled to give it a try, because
they won't be losing anything. If they are somehow able to enact
a repair, then that's good. If they damage it, or at the very least
can't fix it, that's good to because they were going to throw it
out anyway.
Repair first requires troubleshooting, ie figuring out by available
information about what's wrong. You "figured" it was the CCD because
you didn't get a display. But you ought to have taken some pictures,
to determine whether it was merely the display, or something earlier
on in the camera. If it was merely the display, then you'd get lots
of good pictures.
Whatever the original problem, you seem to have compounded it by
whatever you did when you opened the camera.
Michael
AJ
@ this point contact Canon, findout what they will charge to r/r the item.
(Repair or Replace).
Jose Capco
on in thecamera. If it was merely the display, then you'd get lots
of good pictures.
I did take pictures which of course turned out to be blanks, and Axx
series did have problems with Sony's CCD and Canon was offering repair
(during that time I did not know, now I don't think Canon accept such
repairs.. they even didnt announced it in Europe). Anyway, the camera
is past its gaurantee limit ...
And yes, I did realize that the repair cost will be just as much as
the cost of a new camera.. and that otherwise the camera should be
discarded... that is why I opened it =)
I read several posts on digicam repair.. and I havent seen one in
which someone said with confidence that he/she was able to repair
them.. so I guess its time for a new digicam :)
Anyway, if anyone is interested in camera parts I would gladly send it
by post. It would be a pity if I just discard the camera. I might,
worst case, just keep it... if I have the time I can experiments on
some parts, maybe I can use the CCD sensor or the lenses to do
something cool :)
I actually asked because I thought maybe digicams have specialized
built.. maybe.. they have some secret mechanism that if an ordinary
radio technician opens it he will destroy the circuitry in some sort..
but I guess Im thinking too deep :p
Sincerely,
Jose Capco
W
Warren Weber
Sincerely,
Jose Capco
Jose I too have a minor repair needed on a Olympus. Detent on rotory dial
that turns camera on or off failed. So may turn itself on when in camera bag
and run batteries down. Called Olympus Repair. $149 to repair plus postage
both ways. Problem solved. Buying new camera DIFFERENT BRAND. Even though
this brand takes excellent pictures. W W
W
William R. Walsh
Hi!
Here's one. I have an older Sony DSC-P20 camera that started popping up an
error code on every startup. It would beep, flash the error code and shut
down every time. Sometimes it would power up OK, but it was touchy...touch
it and watch it blow up, throw the error and shut down again. It got to the
point where I had to use the timer to take pictures--just pressing the
shutter button would set it off. I did notice that the "InfoLithium" logo
that's displayed when using an InfoLithium battery would vanish if the
camera was going to throw the error, and this should have clued me in.
I put up with this for a long time before finally breaking out the
screwdrivers. This camera isn't very high resolution by today's standards,
but it does take excellent VGA-resolution pictures...which is what I want to
do with it above all else.
When I got it apart, the camera worked perfectly. I couldn't faze it by
tapping, shaking or touching anything. Put it back together and it was right
back up to its old tricks. I finally did get it, though. When I took it
apart a second time, it decided to keep malfunctioning. Only this time, it
put up a message telling me something along the lines of "for Sony battery
only". It turns out that the battery door had become just ever so slightly
splayed out at one hinge. This made whatever set of contacts Sony uses to
detect InfoLithium packs fail to make good contact.
I glued a very tiny shim to the back of the battery instead of trying to fix
the hinge on the battery door. I also cleaned the battery contacts a little,
although they did not look too dirty. While I had heard that some Sony
digital cameras had problems with dirty contacts, this one wasn't mentioned
in anything I read. Ever since I added the little bit of material to the
back of the battery, the camera has been absolutely reliable.
There you go. Now you have heard of a successful repair. By the way, I did
search against the fault code that my camera was returning. Every answer I
found suggested the memory stick was failing, but that's clearly not
correct. I'm still using the same Memory Stick.
It wouldn't be unheard of. I've not heard of it in cameras, but some TV sets
are said to have so-called "trap" switches that you can get into trouble
with.
I would look for obvious but hidden stuff. You could have pulled a ribbon
cable loose or disconnected a ground that the camera requires to operate
properly. Has it got a reset button? If so, did you press and hold it for a
while? I think there is a possibility you might still fix it or at least get
it turning on again.
William
K
Ken G.
I have had some luck fixing a few digital cameras and camcorders but i
had others on hand of the same model to rob parts from .
The assemblys and boards are usually just replaced by those service
centers .
Taking one of those apart and getting it back together is a chore itself
I too have made some worse because i got one little connector back on a
tiny off center that caused a short .
They were useless before hand anyhow .
