Digital Clock Speeding Up (ie Gaining Time)
Hi guys.
I had a typical digital alarm clock for a few years. I noticed it
started to report the time a few minutes fast. If I reset it the time
would still go forward.
I'm estimating it gains around a minute a week. This doesn't sound
like much, but in 6 months the clock is half an hour ahead of the
correct time.
I thought the clock might be playing up because it is plugged in with a
dozen other electrical devices (computer, home theatre etc). To
confirm I plugged it into another socket on it's own in another room.
The problem persisted so I threw it out.
I got a new clock, and after a few months it is 20 mins ahead!
Does anybody know the cause of this problem?
Thanx 4 looking.
David L. Jones
Hi guys.
correct time.
Thanx 4 looking.
Most mains powered clocks derive their time form the 50Hz mains which
is very accurate over a long time period. So your clocks are most
likely picking up noise on the mains that is causing missing pulses or
some such problem. Try adding a good mains filter to the clock, or just
get a clock that does not rely on the 50Hz mains (usually the battery
powered type).
Dave :)
Brian Goldsmith.
some such problem.
****What???
The clock is supposedly gaining time,not losing it!
If it is missing "pulses" it will lose time!
Brian Goldsmith
David L. Jones
some such problem.
****What???
Oops, I meant "extra" pulses.
Dave :)
Phil Allison
** Groper Alert !
correct time.
** Likely the clock is not being powered by the AC mains supply on a 24 / 7
basis.
During the unpowered periods, the internal ( battery powered) time base
oscillator takes over - and it runs a tad fast.
Maybe the missus uses it power outlet for her vacuum cleaner or her steam
iron or her ............
........ Phil
F
Franc Zabkar
Hi guys.
correct time.
Thanx 4 looking.
There was a clock that featured in a thread at sci.electronics.repair
some years ago that was affected by off-peak pulses or "remote-reading
electrical power meters" or similar signals.
http://groups.google.com/group/sci.electronics.repair/msg/159076a073f7a83e?hl=en&
- Franc Zabkar
Thanx 2 everyone who replied.
When you say battery powered clocks, do you mean regular alkaline
batteries? If so, wouldn't battery powered clocks lose time when the
battery goes flat? And, wouldn't they go flat often?
I don't think my clock has a battery at all. Whenever power is lost
the clock is reset to 12:00.
I noticed the clock on my microwave keeps the right time. Does that
sound right if there is a problem with the power here?
Is this the type of filter I should be looking at getting?
http://www.dse.com.au/cgi-bin/dse.filereader?45362276029a446c2741c0a87f9c06f4+EN/catalogs/CTG0001024
Phil Allison
When you say battery powered clocks...
** No one mentioned *any* such thing.
You asinine Google Groups WANKER !!
....... . Phil
David L. Jones
No, an LCD display clock should last for years, just like a digtial
watch.
Something like this:
http://www.dse.com.au/cgi-bin/dse.storefront/45369dd009708ca0273fc0a87f9c074e/Product/View/Y0621
That means it most likely has better designed circuitry (filtering)
that gets pulses from the 50Hz mains. With your other clocks you have
just been unlucky with a poorly designed product - twice.
None of them seem to have the word "filter" in them, just "surge
protection", that is different. Not that a filter is guaranteed to work
anyway, cheaper to simply buy an LCD digital clock.
Dave :)
