digital tachometer
baja
May 18, 2004
4
Well,
I want to set up the digital tachometer on my bike and I need a formula to calculate the frequency relation to RPM.
I tried with this one Hz=(number of cylinders * RPM/120) but..... ???
The Bike has one cylinder, four strokes and it has two sparks per revolution.
ante1
Jan 24, 2004
4,136
Hi baja,
What kind of motor is this? A normal one cylinder four stroke fires once for every two revs. And this will calc. (Hz = 0.5 * revs.).
Ante ::)
baja
May 18, 2004
4
Hi Ante!
I removed the old battery ignition system and put the flywheel magneto cdi ignition.
This data I picked up from www.aet.si:
Flywheel magneto:
4-pole, rotor diameter 103mm
Triggering:
internal, 2 sparks per revolution
Spark type:
AC arc discharge
Ignition electronic:
C.D.I.
Maybe I have to calc, Hz = 2 * revs
8)
ante1
Jan 24, 2004
4,136
Beats me!
Is there some gearing, say 4:1 from the crankshaft to the magneto?
Ante ::)
baja
May 18, 2004
4
Yep, I got it!! ;D
dig up the formula on the web, which is fairly simple. I have to multiply, pulses/rev*rev/min then divide by 60sec/min and that equals Hz or ignition pulses per second.
In my case; 50Hz is 1500rpm
beauty lies in simple things
Cheers!
