N
Nicholas Kinar
- Jan 1, 1970
- 0
Hello--
I'm working with an experimental acoustics sensor which will produce
voltages ranging between 0.5 microvolt (minimum) and 5 V (peak to peak).
What is the best way to digitize this signal? At first blush, it
appears that a 24-bit ADC would work quite well for this type of
application, since (5V)/(2^24) = 3E-7 Volts. However, would it be
better to do the following?
(1) Convert the voltage signal into a current using a transconductance
amplifier.
(2) Use a logarithmic amp to find the logarithm of the current. The
AD8304 from Analog Devices is a 160dB (100 pA to 10 mA)) logarithmic amp
used as a photo-diode detector:
http://www.analog.com/static/imported-files/data_sheets/AD8304.pdf
(3) Digitize the voltage output of the AD8304 log amp using an ADC.
BUT how do I determine the number of bits of my ADC? The logarithmic
amp will take the logarithm of the signal, but how do I choose the
number of bits of the ADC so that I can adequately measure the range of
voltages?
OR is it best to simply use a 24-bit ADC?
Nicholas
amplifier.
voltages?
Nicholas
