diode temperature coefficient
K
kell
Some references describe diode tempco as -2.1 mV per degree C and also
as 3300 parts per million.
If parts per million, then the tempco would vary with the forward
voltage of the diode, for example, with a very low forward current, Vf
could be half a volt; at 3300 parts per million that comes to about
-1.7 mV. So is it -1.7 or is it -2.1; in other words is tempco a
constant or is it a proportion of Vf?
John Popelish
The voltage across an ideal diode is the natural log of a ratio of
bunch of terms that involve doping densities and thicknesses and
widths multiplied by the diode current. And that log is multiplied by
k*T/Q.
The derivative of all that with respect to T is the same thing with
the T replaced by 1. So as long as the current is constant (and all
those other constants do not vary with temperature), the slope is
constant, or a fixed increment per degree, not a fixed fraction of Vf
per degree.
Pooh Bear
k*T/Q.
per degree.
And don't forget to factor in the IR drop due to bulk resistance.
When using diodes or Vbe like that to monitor temp I typically run them @
around 1mA or less.
Graham
pebe
als
voltage of the diode, for example, with a very low forward current V
Temperature coefficient of the p/n junction is approx -2mV/deg.
It does not depend on Vf
John Fields
On Sat, 26 Nov 2005 00:01:08 -0600,
Temperature coefficient of the p/n junction is approx -2mV/deg. C
It does not depend on Vf.
K
kell
I didn't notice this before, but in John Popelish's response he says
that
"as long as the current is constant," tempco is constant.
Since Vf is a function of current, and tempco
varies with current (if I interpret correctly), then tempco would vary
with Vf.
But I guess we're not talking about anything simple or remotely linear.
