Diode - Temperature
M.Sridhar
Sep 16, 2015
10
How to measure temperature using diode.Can it be used in such a way?
ed181
Dec 27, 2010
15
Why would you want to measure temperature using a diode?
ed181
Dec 27, 2010
15
You can but it looks like a lot of work and it won't be accurate
Arouse1973
Adam
Dec 18, 2013
5,178
Yes it can. A common method is to use a transistors base emitter diode. Simply pass a constant current through the transistor configured as a transdiode. Have another reference like a potential divider also with a constant current passing through it. Connect this to a comparator and calibrate for use. As the temperature changes the transdiode voltage will change and this can be sensed by the comparator.
Adam
Alec_t
Jul 7, 2015
3,818
The junction voltage of a diode changes by about -2mV per deg C rise, but if you want to experiment you can use the base-emitter junction of a transistor in an 'amplified-diode' configuration as shown in the attachment, to give a greater change.
This behaves like a diode with a 0.6V junction voltage multiplied by approximately (1 + R1/R2), and a correspondingly multiplied change with temperature.
Arouse1973
Adam
Dec 18, 2013
5,178
The BE junction of a transistor changes by the same amount. They are all PN junctions.
Alec_t
Jul 7, 2015
3,818
Correct. The 'amplified diode' voltage appears between the collector and emitter terminals in the circuit shown.
AnalogKid
Jun 10, 2015
3,050
Check with Linear Technology, Maxim, Analog Devices. Somebody out there has a chip that uses a diode as a temperature sensor and turns it into either a thermometer or a thermostat.
ak
