flippityflop1
- Jan 27, 2009
- 135
- Joined
- Jan 27, 2009
- Messages
- 135
i know this is a stupid question but i'll ask away anyways...
are there any diodes that instead would have a specified *current breakdown* rather than a voltage breakdown? i know it's stupid coz the current would have to flow first to know the amp to know when it should break, but the diode is already hindering that flow in the first place.
in an analogy of transistors, diodes are dependent on voltage, as are FETs. the BJTs are dependent on current.... so are there any diodes dependent on current too??
(though the analogy is somewhat forced, as diodes actually work on the same principles as BJTs, not FETs -- other way around -- but i'm just illustrating a point).
the best compromise i could think of was an NPN or PNP semiconductor, where the gate is connected to a V+ or common ground, respectively. then a small current flowing through base-emitter would cause the base to "breakdown" at the desired current. courtesy of (typically) smaller current (proportional to reciprocal of gain) flowing deep inside the base-emitter junction. this will allow an avalanche through emitter-collector. but chances are, it's already implemented as a BJT transistor... (still reading wikis for avalanche transistors, actually).
anyways, i still prefer it to be in diode implementation, so if it exist, please hit "reply"
