Hi.
If a 1 Watt little solar panel outputs 4.0V at full sunlight; direct feeding a lithium cell will charge it to that maximum 4.0V at a maximum capable rate of 0.25A into a discharged cell, reaching perhaps ~85% state of charge.
If the solar panel is 4.5V instead; it will apply overvoltage to the cell exceeding limitations.
If the solar panel is 5.0V instead, same as above but a 0.7V drop diode can be inserted in series to lower voltage to 4.3V maximum.
If the solar panel is 6.0V or more, a direct connection is not recommended.
But : If the solar panel is an even smaller, weak one, of lower current capability, voltage will collapse to the point of not harming the cell loading it? Unless left too long connected allowing reaching over ~4.3V ?
Extreme example: Can this also harm the cell ?
6V source(+)-----------------100KΩ-------------(+)18650(-)--------------------(-)
