Anthony_Starfield
- Nov 20, 2015
- 4
- Joined
- Nov 20, 2015
- Messages
- 4
Good Day,
I'm looking at building this LED light panel. Matthew steps through the project. He did a fine job, but I'm a beginner and I don't know the lingo on voltage regulators.
Here is the project:
http://www.instructables.com/id/How-to-make-a-super-bright-LED-light-panel-for-vid/
Matthew used a voltage regulator, along with a resister and a 22,000 ohm potentiometer.
There are some bad reviews for that voltage regulator on Amazon. One of the reviewers even had a capacitor that blew up and burned a his forehead! And it comes from China. So it will probably be 2 weeks in the mail. Plus it would by handy to use one that has a readout panel for the voltage.
In the video, Matthew said the voltage regulator has a direct current output of 6 to 12 volts.
Can I use this direct current voltage regulator?
Yeeco 4.0-40V to 1.25-37V LM2596 DC to DC BUCK Converter step-down Car Motor power supply Voltage Regulator with LED voltmeter DC 36V to 24V to 12V to 5V
http://www.amazon.com/Yeeco-Convert...&sr=1-18&keywords=step+down+voltage+converter
The first line starts with:
Does this mean the input is 4.0 to 40 volts, and the output can be adjusted from 1.25 volts to 37 volts?
And if I use this voltage regulator, could I do without the resistor and 22,000 ohm potentiometer? Or do I still need them to be sure the minimum voltage never drops below 6 volts?
And for input power, can I use a power adapter from a notebook computer that has an output voltage of somewhere between 4 and 40 volts?
Thank you much for your help. A bonnie fine day to you, Anthony
