do you know geometry?
RichD
Start with a sheet of stiff paper, and a pen.
Draw an outline of a shape, such that when cut
out with scissors, it will fold into a cube.
You're permiited to draw interior folding lines.
Everyone here will regard this as trivial. But
I've tested it on 6 people, and only 2 got it
the first try. Try it on your friends and business
associates.
Don Y
It's obvious, or should be to any engineer. You just envision a box,
and unfold it in your head.
It's basically a Christian cross.
You can do it with a *square* piece of paper.
George Herold
associates.
Weird.. do they only do five 'pieces' a base and four sides?
m II
My problems are the interior folding lines. When I try to draw them, I
don't have an interior anymore. There is something Zenish going on here.
mike
m II
Just be in the box.
So...you're implying that it's my *unfolding* of the box that causes the
interior to disappear...This three dimensional space of yours is
certainly taking getting used to.
mike
Robert Baer
associates.
Maybe because there are so many ways it can be done?
I thought of 2 ways in less than 2 minutes and quit because it is so
simple.
Robert Baer
Check.
Don Y
Hi David,
It's that small a number only if you restrict yourself to those
configurations in which each face of the cube must consist of a single
square cut out from the original sheet, and joins can occur only at
the face-to-face edges of the cube. That's a limitation which was
*not* specified in the original statement of the problem.
Exactly. There was no mention as to how *complex* the folding
process was expected to be.
(Nor any mention as to whether or not the folded paper would *hold*
the shape of its own accord)
If even one face of the cube is allowed to be made from two or more
non-overlapping (but exactly-joining) sub-faces made up of non-square
portions of the shape that you cut out (i.e. these sub-faces meet in
the middle of one of the cube's faces), then there are an infinite
number of cutout shapes which will qualify.
Yes. I know of at least two different ways of folding a
perfectly *square* piece of paper into a cube (without the
benefit of scissors). I could probably come up with more
if pressed...
And, by extension, any rectangular piece of paper (I think all
I need is a right angle, somewhere).
You just have to NOT think in "pedestrian" turns. Think
outside the box -- er, *cube*! :>
Martin Riddle
associates.
How big is the cube going to be? Your light on design input;)
I got a 11 x 17" piece of paper here.....
Am I allowed to use a ruler?
Cheers
Jasen Betts
there's several shapes that work
possibly posibly others too...
Jasen Betts
Even if you are it won't be a perfect cube, so presumably any
recognisable approximation is acceptable.
If you start with an acceptably rectangular piece of paper, by folding
it you can create a regular square grid. (fold a 45 degree angle to
translate east-west measure to north-south)
Jasen Betts
On Thu, 22 Aug 2013 16:23:38 -0700 (PDT), RichD
associates.
That can't be right. John Fields has declared that there are only six.
When covering the surface of a cube one must think outside the box :)
Robert Baer
John said:
Or:
_ _ _ _ _ _
|_ _|_ _|_ _|
|_ _|
|_ _|
|_ _|
Or:
_ _ _ _
|_ _|_ _|_ _
|_ _|_ _|
|_ _|
|_ _|
Or:
_ _ _ _
|_ _|_ _|
|_ _|_ _
|_ _|_ _|
|_ _|
Or:
_ _ _ _
|_ _|_ _|
|_ _|
|_ _|_ _
|_ _|_ _|
Or:
_ _
|_ _|_ _
_ _|_ _|_ _|
|_ _|_ _|
|_ _|
OR:
_ _
_ _|_ _| <-- top
_ _|_ _|_ _| <-- front,right
|_ _|_ _| <-- left,bottom
|_ _| <-- back
This gets rid of the boring 4-in-a-row design.
Robert Baer
Here is a collection of some of those given:
1A 1B 2A 2B
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
|_ _|_ _|_ _| _ _|_ _|_ _ |_ _|_ _|_ _ |_ _|_ _|
|_ _| |_ _|_ _|_ _| |_ _|_ _| |_ _|_ _
|_ _| |_ _| |_ _| |_ _|_ _|
2C 3 var A var B
_ _ _ _ _ _ _ _ _ _
|_ _|_ _| |_ _|_ _ _ _|_ _| |_ _|_ _
|_ _| _ _|_ _|_ _| _ _|_ _|_ _| |_ _|_ _|_ _
|_ _|_ _ |_ _|_ _| |_ _|_ _| |_ _|_ _|
|_ _|_ _| |_ _| |_ _| |_ _|
var C
_ _
|_ _|
_ _|_ _|
|_ _|_ _|
|_ _|
|_ _|
Jasen Betts
1A 1B 2A 2B
2C 3 var A var B
_ _ _ _ _ _ _ _ _ _
var C
_ _
|_ _|
_ _|_ _|
|_ _|_ _|
|_ _|
|_ _|
I just thought up some more...
_ _ _ _ _ _
|_ _|_ _| |_ _|
|_ _|_ _ _ _|_ _|_ _
|_ _|_ _| |_ _|_ _|_ _|
|_ _| |_ _|
Having one tile different to "1B" and "2B" or "Var A" or "Var C"
I can's see how to classify them
That makes 11, I can't as yet complete the dozen, if that's possible.
DecadentLinuxUserNumeroUno
Maybe you should learn to read. I did not see where it was him making
that remark.
that remark.
Robert Baer
_ _ _ _ _ _
|_ _|_ _| |_ _|
|_ _|_ _ _ _|_ _|_ _
|_ _| |_ _|
Yep!
How about a strip of paper of uniform width (== box size)?
Use 45 degree fold after front, top, back, bottom are made - to allow
sides. Nothing was said about doing a surface twice..
