Do you think splicing 100' of wire onto a GTO exit wand would work?
Elmo
I bought too short of a driveway-gate exit wand (GTO FM139 = 50 feet); I
need 150 feet.
Nobody told me (so I'm saying it here), one really needs about 150 feet if
they want the driveway gate to be open by the time the moving mass of metal
(i.e., automobile) reaches the gate. Lesson learned.
Researching the web, it appears GTO sells three wands:
http://www.gtopro.com/access_controls.htm
- FM139 = 50 feet wired (about $180)
- FM140 = 100 feet wired (about $200)
- FM141 = 150 feet wired (about $225)
The instructions say you can not splice additional lengths
(http://www.gtopro.com/PDF/Flyers/Gate-Opener-Access-Control-FM139-vehicle-sensor.pdf
Calling www.gtopro.com technical support at 800-543-4283, they say there is
no difference between the wands or the wire other than the length BUT if I
splice in a wire, it won't work.
The technical support guy was very helpful. He said the reason it won't
work is that the "sensitivity of the magnetic field" changes with the
splice.
I don't understand why (if I make a good splice) but maybe there is
something about magnetic fields I don't understand that you can elucidate
for me? The wire is 5 conductor 16awg multi-strand shielded.
What is it about a splice that destroys the magnetic field?
W
William Sommerwerck
reason it won't work is that the "sensitivity of the magnetic
field" changes with the splice.
On the face of it, this is a pile of manure.
It's possible (as someone else said) that the system might be calibrated for
specific cable lengths, and it might be difficult to splice the wire in such
a way as to maintain the desired electrical characteristics. But an amateur
antenna system has at least two "splices" in it -- one at the transmitter,
the other at the antenna -- and it works fine.
If the folks running the company are "nice" people, they should take back
the too-short cable -- even though it's been used -- and give you full
credit towards a cable of the right length.
GregS
need 150 feet.
or.pdf
splice.
First thing, how do you get IN ????
Second thing, try an additional 5-10 feet and see if there
is something other than ??
Whats the connector look like ??
greg
George
They didn't say they couldn't get any but that the gate didn't open fast
enough for the speed they were driving. Obviously one solution might be
to go a little slower.
GregS
to go a little slower.[/QUOTE]
This is for exit only. I asked how do they get in, thinking any decent gate
will have a remote control. Go through same procedure as to get
in, push button. !!!! That RF is a usefull thing !!! Remote control !!!
A magnetic sensor is usefull to prevent closing the gate and hitting car.
greg
mm
I know that when my girlfriend got spliced, it destroyed our magnetic
field.
Seriously, I'm a 3 or 4 out of 10 on electronics knowledge, not even a
skilled amateur, but this reminds me of "No user-serviceable parts
inside". It depends on who the user is. I even saw that on a Black &
Decker tire pump, on the plug for the cigarette lighter. I drilled
out the rivets, replaced a burned-out fuse, and it's worked fine for
10 years now.
The product you write about seems intended for corporations and rich
people. I'll bet it's a way to squeeze another 150 dollars out of
you.
(They won't exchange what you bought for the longer one because you
buried yours already and it's dirty?)
Oh, yeah, the technician might even believe what he told you even if
I'm right.
It would be easier to do a nice splice if you offset the individual
splices an inch or so from each other.
To the other people here, any reason he can't use one sheet of
alimumim foil to shield everything all at once.
If you're burying it when you're done, silicone tape, I think it's
called, is even better than heat-shrink tubing and doesn't slip on, it
wraps on. Stretch it to 2 or 3 times its length, then wrap while
streched and within a few days it merges into one big probably
waterproof blob. Hard to find though.
Elmo
There is a keypad to get in, and a remote.
Both work fine for the owner of the house, but not for guests.
Guests enter via the outside-the-gate intercom keypad.
But the gate closes 25 seconds after being opened.
When guests leave, the exit wand triggers the gate to open.
Elmo
There is no connector. Each of the four 16 AWG multi-stranded wires arrives
from the factory stripped of about 1/4 inch at the ends and tinned solid.
We just screw those four wires plus the shield into connections on the gate
opener motherboard.
Elmo
Guests won't have a remote control nor will they have the keypad
combination.
Elmo
Could be like the gate at a corporate site I occasionally visit - for
entry, you speak to a guard and show ID via a TV camera and the guard
opens the gate. A device like the one in this thread is used to allow
people to exit the gate.
Yes. The "typical" gate setup is:
1a. Owner approaches gate and flips remote control to get in.
1b. Utility truck approaches gate and pushed their logged 4-digit combo on
the digital keypad to get in (whether or not someone is home)
1c. Guest arrives and has to press the intercom button and can only be let
in if someone inside the house provides them access. Guest then pushes a
button on the keypad to open the gate.
2. In all cases above, the gate closes 25 seconds after it was opened.
3. In all cases above, when the owner/utility/guest leaves, the gate
automatically opens for them via the exit want magnetic field disturbance
sensor.
At least that's how my gate is set up. Some are set up to open via
cellphone but mine isn't fancy.
PeterD
opener motherboard.
The simple answer is just try it! What do you loose, a few minutes of
time?
That said, just make sure your splice is absolutely waterproof. 3M
makes underground splice kits that may work (used primarily for telco
work).
W
William Sommerwerck
Why has no one paid attention to my suggestion?
Get the manufacturer to give you full credit towards a longer cable.
Elmo
3M makes underground splice kits that may work
I have to find the 4-wire multi-stranded shielded cable first ... but I
will try the splice kit at the same time if I can find that also.
This morning I called GTO technical support again at 800-543-1236 and spoke
this time with a woman with a southern accent who told me a splice could be
done, but she said the problem is that it will eventually break. And, since
it will be underground, I won't know where it is and I'll be calling
technical support who won't know that it was spliced while they
troubleshoot.
When I asked "but CAN it be spliced?", she confirmed there is no difference
in the wand itself between the longer lengths of wire as the sensitivity
adjustments are done on the gate control board itself.
I'll look for that 3M waterproof splice kit. I think I'll need a
low-voltage splice kit. According to this web site, the voltage is 8 to 32
VAC or 8 to 26 VDC with a miniscule current of 1.5ma.
http://www.allsecurityequipment.com/proddetail.asp?prod=GTO-FM141
Elmo
(used primarily for telco work).
Great idea! If it works for the telephone company, it should work here.
On the 3M web site, I found a splice kit for 3-conductor "armored" cable,
but not 4 conductor (and it was for 10-14 AWG, not 16AWG).
Here's the product information from: http://tinyurl.com/ybrgmlf
http://solutions.3m.com/wps/portal/...E3E02LECIE20OES1_nid=PVQLFM5BXCbeGCC8VFQJBCgl
- 3Mâ„¢ 3/C Low Voltage Splice Kit 5730, 14-10 AWG (UPC 00054007431718).
- These kits are applicable for indoor and outdoor installations,
- including direct burial, aerial and submersible applications.
- This kit requires 1 roll of 3Mâ„¢ Armorcastâ„¢ Structural Material.
Do you think I can find a 4-conductor shielded 16 AWG cable splice kit at
ACE, OSH, or Home Depot? (I'll try later today.)
Elmo
I'm right.
I think the technicians have to say what's in the manual:
http://www.gtopro.com/PDF/Manuals/GTO-Gate-Opener-Gate-Operator-Manual-pro-wand.pdf
On Page 2 of that PDF installation manual, it says:
- The Wand cable CANNOT be spliced.
- If you need more wire, contact the GTO Sales Department at 800-543-GATE.
When I called the GTO Sales Department, they said the only solution was to
buy a new exit wand with a longer feed. They said all the exit wands are
different (contrary to what the technicians told me at the support number).
GregS
sensor.
I am familiar with only one setup. A sewage plant. The opperator
controls gate open or close, and the pickup prevents the gate
from ramming into the vehicle.
You must have many guests and visitors to warrent this setup you have,
greg
