please_post_to_groups
- Jan 1, 1970
- 0
Does anyone know a way to take an audio signal and output it multiple times
with different amplitude and phases tia sal2
Greetings All
I have one source for an audio signal and would like to send it to 8 different outputs
simultaneously, but would like to be able to change the phase and amplitude of each of the
8 outputs separately.
I was thinking of using 8 small amplifiers (which isn’t cheap) to increase the amplitude
of the 8 output signals but I’m not sure how I can change the phase of each signal separately.
Is there a product on the market that is inexpensive or can someone recommend a circuit
I could build?
I would use an oscilloscope to make sure the phase and amplitude of each of the 8 outputs
is where I would want it.
Example:
Source is a sine wave generated by a laptop
Output 1) starts at 0 degrees
Output 2) starts at 10 degrees out of phase increase amplitude by 1 volt
Output 3) starts at 15 degrees out of phase
Output 4) starts at 40 degrees out of phase
Output 5) starts at 60 degrees out of phase increase amplitude by 3 volts
Output 6) starts at 100 degrees out of phase
Output 7) starts at 120 degrees out of phase
Output 8) starts at 126 degrees out of phase
alt.sci.physics.acoustics,sci.electronics.basics,sci.electronics.misc,rec.audio.misc
Tia
Sal2
Greetings All
I could build?
Example:
Tia
Sal2
