Does the antenna only increase transmitting range or can it increase reception in regards to flipper zero and the CC1101 Wireless Module?
Maglatron
Jul 12, 2023
2,025
have a look and tell me what you think!
Martaine2005
May 12, 2015
5,318
The or an , antenna will only do its job for what it’s designed to do.
Sorry, I have no idea about the flipper.
But yes. The antenna recives and transmits.
Would you care to elaborate?.
Sorry, we don’t allow or contribute to hacking. It’s against the forum rules.
Most hacking destroys your personal equipment.
Martin
kellys_eye
Jun 25, 2010
6,512
The purpose of an antenna is to afford some form of 'gain' to the signal regardless of the direction of energy flow i.e. transmitting or receiving.
Such gain is a function of many physical aspects of the antenna design, not simply length. Antenna gain is associated with its radiation pattern which itself is plotted over 360 degrees at a fixed distance from the radiator element. You can increase the gain but at a loss (a decrease) of reception (or transmission) 'width' i.e. the higher the gain the more directional the antenna becomes.
It's a very complex interaction and not possible to explain in the simpler confines of this forum but there are many books - and no doubt videos - on the subject if you care to search for them.
Delta Prime
Jul 29, 2020
2,996
Use only for reference please.
  • antenna_information.pdf
Maglatron
Jul 12, 2023
2,025
I don't understand about the learning comment. what did you mean?
Delta Prime
Jul 29, 2020
2,996
It's an unwritten rule! A type of common courtesy. When you drop the ball,you get" called out" by your peers in a good way. You have to register and or pay to gain
access to the information, it's best to provide knowledge when it's free to access,like a library.
It's easy for me cuz I get logged in automatically and some time forget like being a member of IEEE.
Or other institutions Massachusetts institute of technology, California institute of technology, National Institute of Standards technology , so on and so forth.
