Doors AND wall activated cabinet lights
RanyR
Feb 6, 2023
Hi all,
I am trying to design a led-light system for my closet room (the lights are low-voltage so must use a driver).
I have seen a lot of designs but it seems what I want is a little different.
I want:
1. The in-cabinet light of a specific cabinet to go on when its door is opened.
2. The in-cabinet lights of the entire closet room to light up from a wall switch.
I am not an electrician but this doesn't sound too complicated - but both my carpenter and electrician state I can have one or the other but not both.
For the life of me I don't understand why.
If anyone can share their two cents that would be much appreciated.
Rany.
Martaine2005
May 12, 2015
5,318
Of course it can be done.
But it obviously depends on the lighting sets you have.
1. The electrician is lazy
2. Why would a carpenter know?.
You will need each cupboard to have a separate light, driver and switch.
The main wall switch will control ALL drivers.
The cupboards will need a separate LIVE feed and normally open door switches. The main wall switch LIVE feed simply ‘jumps’ the cupboard switches.
Martin
bidrohini
Feb 1, 2023
221
Hi all,
I want:
Rany.
I think you can proceed with a magnetic door switch, Arduino UNO and relay module.
www.theengineeringprojects.com/2012/10/introduction-to-relay.html
