doubt cooler tvbox
Status
Not open for further replies.
gamer87
Mar 11, 2017
261
In a device such as a TV box with a width of 8cm and air vents at the bottom, if I place a USB cooler underneath as an exhaust fan, the cooling will be more powerful as an exhaust fan of a cooler of the same size as the 80mm box or a cooler larger than 120mm? I have the T95 max Plus
bertus
3,868
When it vents to the bottom, place some higher feet under the box to have a more free outlet of the air.
The fan of the box should be enough.
An usb cooler might even have a negative effect as it will likely blow against the box, giving resistance to the air coming out of the box.
Bertus
Martaine2005
May 12, 2015
5,314
Put it in the freezer. That’ll keep it very cool.
Or store it away and it’ll never get hot.
Martin
Status
