Drill bits for homemade PCBs?
TTL
Oct 24, 2013
195
On a sidenote: apart from the carbide drill bits, what kind of electric drill would you suggest I get for drilling PCBs?
I understand Dremel is the general consensus when it comes to these kind of things, but there are so many types with differing specs.
Are there other things in electronics such a multi-tool may come in handy, or could I just as well just get a cheaper "electric drill" (as opposed to "electric multi-tool") for this use?
CDRIVE
May 8, 2012
4,960
Just about any high speed (=>10,000RPM) rotary tool that accepts 1/8" collets will work well. This includes Routers, Trim Routers, Dremels, etc. IMHO, all of the above should be affixed to a drill press type arrangement. Though it doesn't matter if the rotary tool moves along the "Y" axis with the drill table stationary or the reverse like a machinist mill, where the milling table moves along the "Y" axis.
I will readily confess that when only making a few holes I've opted to use my drill press on its highest speed.
Cheers,
Chris
tilup367
Mar 3, 2014
13
The problem comes from the rotation speed and the pressure when drilling with the press drill. If i take constant and formula from the machinery handbook. As an exemple, the correct rotation speed for 0.7 mm drillbit in alloy-copper : 20 571 rpm. And for the pressure, if hand-push with press drill, you must be slow because those drillbit are really fragile. Other exemple : 0.2 mm drillbit @ 72 000 rpm in alloy-copper, 1.2 mm drillbit @ 12 000 rpm in alloy-copper. In general rule : the smaller, the faster. But at my home, i have a press drill up to 4200 rpm and cartridge drillbit 0.2mm to 1.2 mm. I Run it at maximum speed and slowly hand pushed down, it work perfect and the pcb held thigh with "c" clamp on the press drill work table.
Similar threads
