Driving a piezo sounder
  • Thread starter Martin Griffith
  • Start date
Martin Griffith
I've just got back to thinking how to drive piezo sounder, and was
wondering if something like the Natsemi LM4908 headphone amp working
in bridge mode would be ok.
The piezo has a 18nF capacitance
The lm4908 seems a lot easier and smaller than brewing my own
Any potential gotcha's?
martin
Eeyore
So what's the Z at the f of interest ?
Don't forget it's reactive either.
Graham
Martin Griffith
Graham
Nowt on the data sheet, just says 3KHz, and a max current of 10mA just
wondering where the 3uS slew rate op the amp comes in to the Eq. I'm
doing an Olimex run in a couple of days, so I'll see if if I can
squeeze a quick test pcb onto the gerbers
Maybe a few R in series will be needed
martin
Eeyore
that's -j2707 ohms
When driven from a fairly high voltage obviously such as 27V.
just wondering where the 3uS slew rate op the amp comes in to the Eq.
V/us ? Hardly sounds a problem for 3kHz. What are the supplies ?
I'm doing an Olimex run in a couple of days, so I'll see if if I can
Ok.
Wouldn't hurt.
Graham
Scott Seidman
martin
Can you pass on the spec sheet for your piezo buzzer?? Many of these have
on-board stuff that works just fine with a TTL signal.
Mike Harrison
It's this, the kpe130
http://www.farnell.com/datasheets/23964.pdf
I'm just trying to make it a bit louder with a push pull drive
martin
If you want louder, put an inductor across it ( 10-100mH - yes milli, not micro) and drive it with
an open-collector transistor at the sounder's resonant peak. Use a HV transistor (e.g. MPSA42) if
there is any risk of the piezo getting disconnected as it will swing over 100V off-load.
Bourns do some nice cheap axial inductors that work a treat.
Martin Griffith
Great, thanks for that tip, I have a go when I put the scope back
together, (fuzzy focus)
martin
