Driving LCD 7-seg passive displays with PIC
I have a passive LCD with 8 7-seg digits plus point and some other
symbol. It has 23 connections.
I wish to drive it with a PIC that has LCD module built-in but I have
seen that all PICs capable to drive LCD have only 4 commons. I
supposed that was needed 1 common for each digit but probably I have
to use bias plus multiplex. In this case how can I do? I have not
found any application notes and info on internet. Thanks.
I wish to use a 16F917 PIC.
linnix
Not really necessary.
but probably I have
You have to double check it for sure, but 8 digits would need 64
segments. 23 pins (19x4) can drive 76 segments. So, it should be
possible.
Spehro Pefhany
What does the data sheet for the LCD show? Definitely multiplexed,
probably by 3 or maybe 4. You need that information.
That's fine.
I
Nope.
Best regards,
Spehro Pefhany
That's fine.
Best regards,
Spehro Pefhany
Can you explain me how the multiplexing with biasing works? I cannot
understand how to connect the wires and why there are different levels
of voltage in common pins rather than only 3 (-V, 0, +V).
linnix
I cannot understand how to connect the wires
There are four common lines from the uC to four common lines to the
LCD. It is definitely a one-to-one mapping.
