DS1621 pc thermometer
gamelektro
May 16, 2006
18
http://www.electronics-lab.com/projects/pc/010/index.html
I can't find the lm 2936-z5 .can 78L05 powered the 2 IC ds1621 without external volt ???
nerdspot
Nov 1, 2006
13
Check this link: http://www.national.com/pf/LM/LM2936.html
The part u need is LM2936Z-5.0 in da list..
Guest
Has any on made this project and got it running in Windows XP. I cant.
Is the pin configuration given for COM port correct also ???
MP1
Dec 7, 2003
3,399
Siddharth,
If you could explain why your project did not work and what you found to cure the problem, it might help someone else if they run into a similar block.
MP
mvadu
Nov 10, 2006
9
Hi Siddharth,
Also please mention from where you get LM-2936, because I could not get it here in Bangalore
Guest
Well.. i had made mistake in the connections on the breadboard....
I made no changes to the ckt.... the pin config of the port is also correct.
LM 2936.. i got from Lamington Rd.,  Mumbai. Was hard to find...  Had to ask at 5 - 6 shops. Costed a 100 Rs.
