dt9205a
mickm3for
Mar 26, 2019
Hi looking for the value of ptc1 in this meter thanks
73's de Edd
Aug 21, 2015
3,730
Me too ! . . . . . . but only for researching its other ends " # " location on the schematic.
As can be seen, it only comes into play, when switched in on the seven different ohms ranges.
S o o o o o o o o o o o o o o o o . . if you had your unit on ohms function and then subjected its probes to 120--220v ! ! ! .
Have you additionally checked to see if the SM 2N9014 at the extreme left bottom schema corner, to see if its zener junction functioning of its C&B to E junction has blown up or shorted ?
mickm3for
Mar 26, 2019
Hi its just below and to the right . The part PTC1 is a 1.5k ptc thermistor ,( a 1.5k resistor works ), yes on 2k ohms range 350v dc to probes took out r6 900ohms (2x 1.8k in par) took out the ptc1 took out tr1 . no other damage now working and calibration is ok. the 1.5k ptc was from alliexpress pack of 50
73's de Edd
Aug 21, 2015
3,730
Great that all came out well.Thanks for the parts specifications to help others.
