Hello Ban,
You should also learn to read the datasheet in a right way. I refer to the
MBR1100 here, since there is no MBR1000 on the site.
1. We use the max. spec., you cannot make comparisons with the typical
specs.
Yes. But when the max specs have hardly any conditions listed (and are
most likely for max reverse voltage) you need to contact the mfg to
obtain more detailed data.
Often max ratings are similar to what you find on the pack sheets of
medication. You've seen it: ".... severe liver damage or in extreme
cases death", but when you are really sick you must take them.
2. Have a look at Vf. With 0.79V at 1A not really a dissipation saver, but
still 27% less than a 1N4002.
A Schottky operated at its abs max is not a smart design IMHO. I do not
do that. Realistically this diode is good for a few hundred mA, above
300mA I'd look for another one.
3. The reverse current is specd *at 2% duty cycle* and 300us pulse width.
Now make that 50% and 10ms and tell me the result pls. Use the 80K/W thermal
mounting. BTW the max values are 0.5mA for 25° and 5.0mA for 100°.
Sure, 5mA would not be a good result as you might burn a few hundred mW
in the reverse phase. However, there is no mention under what conditions
(voltage) this applies. Most likely max. These diodes draw far less. For
a design in you'd need more data from the mfg. Sometimes they give you
that, sometimes they don't (or don't have it). I had to do that for opto
couplers, PIN diodes and other stuff and mostly that was no problem.
Leave your "tricks" in the bag, cannot be more absurd.
Don't know what's absurd about that. A diode that is too small will, as
you pointed out, not save much in terms of Vf. Got to stay out of the
"mushy" range. A diode that is way oversized will cause unnecessary
losses because of reverse current.
