Early Xmas for me :)
14,484
hi gang
OHH ma Gosh!!!!
A VERY well known Japanese based consumer and business electronics company
has just moved out of the unit next to where I work
They left behind several hundred plastic bins of electronics components and hardware
to be dumped - they didn't want to take it to their new premises
I spend some time yesterday afternoon and this morning ratting through the bins
collecting 100's of transistors, diodes, IC's of all types
Also lots of opto couplers, opto choppers, stepper motors, electrolytic caps ... the list goes on and on
I also grabbed many of the plastic bins for myself and for other locals that may want some
I am catalogging a list of parts and will post it online sometime soon.
For anyone one in Aussie, that sees something they would like, let me know and its theirs :) Share the good fortune !!
You lucky bugger!
shrtrnd
Jan 15, 2010
3,902
You should have rented a moving truck, loaded-up, and used the profits for your early retirement!
14,484
OK
here's a list compiled so far
Item ...... Count ....... Description
2732 3 EPROM
7416 3 Hex Inverting Buffers with High Voltage Open-Collector Outputs
7473 6 Dual Master-Slave J-K Flip-Flops with Clear
27128 1 EPROM
(DT)5A143E 4 Digital Transistor Array, Including Resistors
1N4148 4 Diode
1N5224 12 2.8V 0.5W Zener -- code marking 3381
1S03 3 Photo-interrupter Sensor, right angle mount
2SA1008 3 PNP Transistor
2SA1015 8 PNP Transistor
2SA1444 4 PNP Transistor ( On Heatsink )
2SA413 17 PNP Transistor
2SB595 2 PNP Transistor
2SB751 2 PNP Transistor
2SC1959 5 NPN Transistor
2SC3328 10 NPN Transistor
2SC3567 6 NPN Transistor
2SC4742 1 NPN Transistor
2SD1128 1 NPN Transistor ( on Heatsink)
2SD1263 10 NPN Transistor
2SD1276 1 NPN Transistor
2SD1395 1 NPN Transistor
2SD1809 7 NPN Transistor
2SD1838 19 NPN Transistor
2SD560 20 NPN Transistor
2SD633 4 NPN Transistor
2SJ268 12 P-Channel Power MOSFET
6N136 5 High Speed Optocoupler 1Mbit/sec, 2MHz B/W
74ALS00 10 SMD - Quad 2-Input NAND Gate
74HC32 6 Quad 2-Input OR Gate
74HC174 5 Hex D-Type Flip-Flop
74HC244 2 Octal Buffers and Line Drivers, With 3-State Outputs
74HC245 1 High Speed Non-Inverting Octal-Bus Transceivers with 3-State Outputs
74HC273 10 Octal D-type flip-flop with reset; positive-edge trigger
74HC86 2 Quad 2-input Exclusive OR gates with push-pull Outputs (SMD)
74LS04 4 Hex Inverter (SMD)
74LS04 2 Hex Inverter
74LS123 9 Dual Retriggerable Monostable Multivibrators with Clear
74LS156 2 Dual 1 line to 4 line Demultiplexer
74LS221 6 Dual Monostable Multivibrator Schmitt Trigger
74LS244 2 Octal 3-STATE Buffer/Line Driver/Line Receiver
74LS244 8 Octal Buffers and Line Drivers, With 3-State Outputs (SMD)
74LS245 2 Non-Inverting Octal-Bus Transceivers with 3-State Outputs
74LS38 2 Quad 2-input NAND Buffer
93C46CB 5 Serial EEPROM
ADM211EAR 3 Transceiver (SMD)
AN7918 2 Neg 18V Regulator
B81004 15 Schottky Diode, 40V 3A
BA10339 4 Comparator, Quad channel, Open collector and emitter, 36V
BA6266 7 6-channel inverter
BL514 3 Photo-diode ?
CK2605 11 Programmable Logic Device Data I/O
D4713 3 RS232 Driver/Receiver
D71059C 2 Interrupt control unit
D7210C 1 Intelligent Gpib Controller
D78CP14CW 2 8-BIT SINGLE-CHIP MICROCOMPUTER
D82C288-8 4 PROM ( Pre-programmed)
EC-977 1 ?
EC-A325 2 ?
EP-390 5 M-ROM
GP1A01 3 Photo-interrupter Sensor, Vertical mount, sup-ceeded by GP1A50HR
GP1A51HR 2 Photo-interrupter Sensor, right angle mount
GP1S50 7 Photo-interrupter Sensor, Vertical mount
HA16901P 5 Quad voltage comparators
HA17301P 5 Quad Operational Amplifier
HDSP5621 14 Twin 7 segment displays ( LED) Green
HM6116LP-4 1 2048-word x 8-Bit High Speed CMOS Static RAM
KM6264BL-10 3 8K x 8 Bit High Speed CMOS Static RAM
L917 10
LB1268 3 3-Channel High-Current Low-Saturation Driver
LB1650 4 Dual Bidirectional Motor Driver
LM305AP 5 Positive Voltage Regulator
LM393 3 Dual Differential Comparators
LT1081CN 2 Advanced Low Power 5V RS232 Dual Driver/Receiver
M51957 1 Voltage Detecting, System Resetting IC Series
M5230L 3 Variable Output Voltage Regulator (Dual Tracking Type)
M54580P 6 7-Unit 150 mA Source Type Darlington Transistor Array
MB84060 5 14 Bit Binary Counter
MC14001 6 Quad 2 Input NOR Gate
MC14016 2 Quad Analog Switch/Quad Multiplexer
MC1488 6 RS-232 quad line driver
MC3301 2 Quad Single Suppy Op-Amp
MC3486 1 Quad differential line receiver
MC3487 2 Quad Differential Line Transceiver
MTZJ24B 13 Zener Diode
OP11 2 Quad Matched 741-Type Operational Amplifiers
PBL3717 6 Stepper Motor Driver
PS2501 9 6V 50mA phototransistor optically coupled isolator (SMD)
RN1002 1 NPN Transistor (Built-in Bias Resistors)
RN1201 7 NPN Digital Transistor (Built in Bias Resistors)
RN1202 5 NPN Transistor (Built-in Bias Resistors)
RN2002 18 PNP Digital Transistor (Built in Bias Resistors)
RN2201 10 PNP Transistor (Built-in Bias resistors)
RP5C15 2 Real-time Clock
S101DD2 1 Bi-directional Opto Thyristor
S81250AG 4 Transistor ?
SN75114 2 Dual Differential Line Drivers
SN75116 2 Differential Line Transceiver
SN75150 4 Dual Line Driver
SN75160BN 4 8-Channel Bidirectional Transceiver
SN75161BN 4 Octal general-purpose interface bus transceivers
SN75189 10 Quad line receiver
STK6713AMK4 2 unipolar 2-phase stepping motor driver (MOSFET)
STK7563K 3 Voltage Reg Module
T520C 4 Transistor ?
TA75339P 9 Quad Comparator, Open drain-collector, 36V
TC4029 3 Presettable Up-Down Counter
TC4049 10 HEX Buffer Converter - inverting
TC4056 4 LCD Display Driver
TC4069 1 Inverting-Function Buffer Gate
TC40H032 5 Quad 2-Input OR Gate
TC40H245 13 Octal Bidirectional Bus Buffer Noninverted 3-State Outputs.
TC40H273 4 Octal D-Type Flip-Flop
TC40HC373 13 is it the same as a 74HC373 ?
TC4514 7 4-bit latch/4-to16 line decoder
TC4543 3 LCD 7Seg Latch-Decoder-Driver
TC4584 5 Hex schmitt trigger
TC5012 16 Hex Non-inverting 3-State Buffer
TC5066 24 7 x High Voltage Buffer, Non-inverting
TC5092A 1 Analog-to-Digital Converter, 13-Bit
TD62004 4 7CH Darlington Sink Driver
TD62064P 2 4CH High-Current Darlington Sink Driver
TD62781AP 6 8 Channel Current Transistor Array Driver
TD62871 12 8-Ch High Voltage Source Driver
TDA1170 1 Vertical Deflection (TV)
TL7705 6 Supply voltage Supervisor
TP850 8 Photo-interrupter Sensor, Vertical mount
UA741 1 Op-Amp
UDN6118 3 Fluorescent Display Drivers
ULN2803A7 5 High-Voltage, High-Current Darlington Transistor Array
uPC141C 6 Precision Positive Voltage Regulator
uPC271C 5 Precision Voltage Comparators same as uPC/LM311
uPD4712A 5 Quad RS232 Line Driver/Receiver
uPD71059C 2 Interrupt Control Unit
shrtrnd
Jan 15, 2010
3,902
You just did that to make us Colonists in the States mouths water.
