Paul
- Jan 1, 1970
- 0
I'm doing some diode research, and would like to know of any possible
DC voltages produced in the diode due to electrochemical reactions.
It's a palladium-silicide diode, part number SMS7630, but also has
gold. Over time the atoms could migrate. The SMS7630 is a microwave
diode used for small signals. It is not terribly uncommon for the DC
voltages produced by small AC signal rectification from such ZBD's
(zero bias diodes) to be as low as one microvolt DC. The SMS7630 zero
bias resistance is ~ 5400 ohms. Even the slightest *possible*
electrochemical reaction is important-- e.g., diode square law
detectors.
It seems possible, for example, for silicon atoms migrating some
distance into the palladium side to bond with palladium atoms that
previously had no such bond-- diffusion.
I would like to build an experiment to measure this DC voltage
produced by electrochemical reactions. Does anyone have any idea what
DC voltages I could expect? Nano volts, pico volts, etc. The DC
voltage produced by a lead acid battery is temperature dependent,
where the electrochemical DC voltage decreases with an increase in
temperature; -0.022V/°C-- ref: http://en.wikipedia.org/wiki/Lead_acid_battery#Electrochemistry
Therefore, how about measuring the change in DC voltage produced by
the SMS7630 at say 60F versus 90F? I have a two layer metal shield
system (small and medium shields) and an electrometer that produces a
few femto amps bias current. It could detect down to 0.5uV DC, but if
there's no appreciable chance of these diodes producing up to 0.5uV DC
from electrochemical reactions then it could save a lot of research
time.
Please see page 3 of this pdf for details on this diodes structure:
http://web.archive.org/web/20071110...orksinc.com/products_display_item.asp?did=745
Regards,
Paul
detectors.
time.
Regards,
Paul
